Results 1 to 3 of 3
Thread: Mobile welding - need a specific generator?
    Jun 2020
    Do welding units, such as a Multimatic 220 AC/DC (PDF spec sheet), need a specific generator to power it? For example, does that unit require the Miller Bobcat 260 (PDF spec sheet)? Or can cheaper generators be used?
    Apr 2008
    NW ON Canada
    Re: Mobile welding - need a specific generator?
    You need a gen that can put out the required power demand that the welder requires to operate.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Look at the spec sheet. you need 31.3 amp of 230 volt power to operate at 200 amps. So you will need a generator that can supply that power all the time.
    watch out for peak power ratings. a generator can only supply peak power for a very short time. Used to start up a electric motor .
    welder can pull 7.5KW so a peak power 8KW generator may not have enough power.
    Watch the sales gimmicks, read the spec sheets and pick a good generator that can put of the power you need all day long.
Page generated in 1,713,297,045.63465 seconds with 19 queries
