Results 1 to 25 of 32
Thread: What Power Plug is This?
    Apr 2020
    I'm considering purchasing a Lincoln PowerMIG 350MP in the picture below. Does anyone recognize that power plug? My concern is this might be a 3-phase welder. I only have 220 volts single-phase at 50 amps. Will this welder work with 220 volts single-phase (50 amps)?
    My other question is whether or not I should purchase a PowerMIG 350 or a PowerMIG 256? Since I only have 220/50 amps, will the 350MP be limited to the same current output as a PowerMIG 256?
    Re: What Power Plug is This?
    Looks like a standard twistlok like you'll find on most construction sites.
    Can't be more specific without at least seeing the ends....
    Delaware
    Well that plug is most likely to be 3 phase. And you just answered your own questions on the rest.
    Apr 2020
    Thanks for the replies. If that plug is 3-phase, can the welder be converted to single-phase? I looked at the spec sheet and they don't mention anything about 3-phase power. How can that be? Is this a differentr version of the 350MP that only runs 3-phase?
    PowerMIG 350MP: https://www.lincolnelectric.com/en-us/Equipment/Pages/product.aspx?product=K2403-2(LincolnElectric)
    PowerMIG 256: https://www.lincolnelectric.com/en-u...ncolnElectric)
    NW New Jersey
    Doesn't matter what plug us hooked up to it, you need to see the information plate with all the specs for the machine. Some machines run on 3 phase and single phase , others only one or the other. If it does run on single phase 230vac you can run it , but within the limits of your breaker/circuit.
    Do you plan on doing some heavy welding, that looks like a pretty heavy gun. They both probably accept Magnum, and Tweco guns. Are you planning on doing aluminum ? You might want to research features, do you need push-pull , spool gun support ?
    That might make a bigger difference than amps alone.
    I'd be surprised if the let it go with the plug, its probably worth $150-$200 dollars alone. I have a single phase 480 vac plug like that on my Airco 250 Heliwelder., it only draws 50 amps that way.
    Best of luck
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
  6. Likes 12345678910 liked this post
  7. #6
    Apr 2020
    I don't plan to do heavy welding. Maybe only up to 1/4-inch thick steel. But, if I can get this welder fairly cheap, I'll do it.
    I can't find any 3-phase PowerMIG 256 or PowerMIG 350MPs on Lincoln's website. Do they really sell 3-phase only versions of those machines?
  8. #7
    NW New Jersey
    I don't see any powermigs with 3 phase listed on the website, looks like they are all single phase. I see a lot of older linde, airco, miller, and Lincoln 3phase cv power supplies on craigslist(transformer) . I think idealarc CV are the 3 phase power supplies. I would still go by the info plate, could be a weird voltage , or frequency. 383v euro, or 50hz. I think if you get the spec # you can look up the information. Usually its a K-XXXX number. Hope you find a good deal.
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
  9. #8
    Apr 2020
    This welder is up for auction in the next 30 minutes, and I can't ask any questions. I looked at the spec sheet for the Power MIG 350MP and the input power is: 208/230/460/575/1/60. That means only single-phase, right? I can't find anything online that claims the Power MIG 350MP or the Power MIG 256 are 3-phase. The Operator's Manual for the 350MP and the 256 explicitly states single-phase only.
    Is it possible that that plug is single phase?
  10. #9
    Sep 2016
    Detroit, Michigan
    Quote Originally Posted by UserJB View Post
    The 350MP is a single-phase machine only...no 3-phase version. I had a 300MP for a short time...same machine, different wrapper and slightly different software. I ran it on 230V 50amp service with no problems. I don't think I ever ran it at 100%, but I think it would have been fine.
    The 350MP has a lot more features than the 256 does (had one of those briefly as well), but many aren't the sort of thing most folks use regularly...like pulse and pules on pulse. It can also do TIG lift start and stick if my memory is correct. They are really nice machines but the few I've seen go at auction get bid up pretty high because they're expensive new. The other thing is that they often seem to come from shops doing heavier work, so they've often lived a harder life.
    The 256 will handle up to 1/2" thick steel in a single pass and is also a very nice machine, but not in the same league as the 350MP. I ran a 256 alongside my Millermatic 252 and I'm not good enough to tell the difference in weld quality between them...both are better than I am! I've seen a couple of 256s and even the slightly older 255XT sell at auctions for very reasonable prices, and they were in really nice condition. They seemed like machines that were bought for rolling around the shop and doing quick fixes rather than constant production.
    From the sounds of it I'd lean towards the better overall deal of condition and price.
    http://mivise.com
    Millermatic 252 W/Spoolmatic 30A
    Miller Dialarc 250
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  11. #10
    Apr 2020
    Sold for $1500. There's many more for sale. Seems like a good price to me.
  12. #11
    Apr 2020
    I found one with a clear picture of the power plug. That's clearly 3-phase, right? How can that be on a Power MIG 350MP?
  13. #12
    Iím on my phone but that looks like only 3 prong. Single phase if so. As ronsii mentioned it is just a twist lock type connector.
  14. #13
    Apr 2020
    Yes, looks like 3 prong. Okay, so single-phase. Thanks.
  15. #14
    Outside of Raleigh, NC
    The 1/60 at the end of the string means that it is single phase, 60 hz, in the voltages listed in front of it. So you plug will be wired for two legs plus a ground.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
  16. #15
    A shop may have put different plugs on so they wouldn't pull apart when moving machines around. It looks like the power cords are fairly long too. Standard cord is usually about 6-8ft.
  17. #16
    Los Angeles
    That style of connector is CSA-50amp.
    For that application it is a single phase 50amp rated connector.
    But as has been mentioned you can just switch out that connector to the standard 6-50 style found on most welding machines or just hard wire it.
    MM211 (Sold)
    Miller 125c Plasma 120v
  18. #17
    Apr 2020
    Thanks for the help. I did not buy the welder. They had about 100 of these for sale and I was hoping to get one cheap towards the end of the auction. Maybe if the other buyers ran out of money, I don't know. The cheapest one sold for abut $1,800. I think that's a pretty good price. But when you add in the Internet Premuim (18%) Sales Tax (6%) and the cost to get that home ($500 plus two days of travel), it just wasn't worth it.
  19. #18
    Dec 2016
    good price for an mp350.
    these machines are reliable and loaded with features and possibilities.
    try and get one.
  20. #19
    Are they from a rental outfit?
  21. #20
    Apr 2020
    The welders were previously owned by a now bankrupt Oil/Gas equipment company in Colorado. Based on the other items in the catalog, it looks like they welded lots of big tanks. The full catalog is here: https://www.bidspotter.com/en-us/auc...-id-bscmy10530 If you don't want to click a link supplied by someone you don't know (which is a good practice), go to BidSpotter.com, click on All Auctions, then look for "Tri-Point" Day 3. They're selling about 60 Miller XMT 450/350 welders on Thursday.
  22. #21
    A lot of good stuff at the auction. Says from 5 shops so must have been fair size shops. A couple 50 ton overhead cranes!
  23. #22
    May 2012
    Ontario, Canada
    PLUGS don't matter.
    No decent welder sells with a plug
    The user puts it on and it could be anything.
    That plus has three prongs, that's 220 single phase
    Two hots and a ground.
    Three phase has 4 connections, three hots and a ground.
    Read the manual.
    As mentioned, some machines can be run on both three and single phase with some configurations on the inside.
    I've seen welders like that go for a few hundred at auction because the homeowner harry bid up the small machines and left the good ones alone.
    Just buy one if it's cheap enough.
    The first one will not the the cheapest one.
    If you get one of those for five hundred or less, you could even use it as trade in at a dealer for a new machine.
  24. #23
    Apr 2020
    At this auction, I could have a 350MP multiple times for $2000. But when you add in tax, fees, and transportation, it adds up to $3,200 plus two days of my time. Not worth it. If I see a 350MP sell for $500, I'll purchase it immediately.
  25. #24
    IMHO, you're lucky you couldn't see spending the money that was bid. No friggin way I'd buy a welder off an internet auction. That's a lot of coin to lay out for a welder that ya don't even know if it works.
  26. #25
    Jan 2020
    I work with conveyors and sorting equipment that uses these plugs. They're always 220v 3 phase in my case, but they're actually rated 480v 50amp. Here's the end yours would plug into.
Page generated in 1,603,318,358.97858 seconds with 13 queries
