Results 1 to 8 of 8
Thread: Grizzly G0779 Gearhead drill press rewiring
    Fredericksburg, VA
    I have this new gearhead drill press at work. It works fine but the way the barrel switch is wired seems backwards to me.
    Is there an easy way to reverse the wiring?
    Trying to change the wires on the barrel switch seems a bit harder than changing the wires at the motor.
    Can I just move the V1,V2, U1,U2 wires in the box near the motor to change the direction?
    If so, any suggestions?
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
    Soda springs,Id
    Re: Grizzly G0779 Gearhead drill press rewiring
    If it's 3 phase just switch two wires at the breaker panel unless there's other motors on the same circuit then don't as they'll then run backward. Better get someone qualified to do it at the drill so the smoke don't leak out.
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Fredericksburg, VA
    It is single phase 220
    Millermatic 252 MIG
    Dec 2016
    did you check in both high and low gear? some machines spin in reverse in one of the speeds.
    but yes,you should be able to do it the motor.
  5. Likes psacustomcreations liked this post
  6. #5
    Is there a manual available for it? I have seen quite a few grizzly manuals and they are great when it comes to schematics...
    ***DANGER***This is just a guess!!! so don't do it unless you check the switch with an ohm meter FIRST to confirm operation of the poles!!!!! My guess is switch the U's 1 with 2 , 2 with 1 and the V's same thing....
  7. Likes psacustomcreations liked this post
  8. #6
    Oct 2013
    Long Island, NY
    I felt it was backwards as well.
    But i just got used to it. It’s muscle memory now.
    www.FirehouseFabricators.com
    Zach
    Lincoln 210mp
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
  9. Likes ronsii, psacustomcreations liked this post
  10. #7
    Fredericksburg, VA
    Yesterday I used it for a couple of hours turning it on and off repeatedly as I was milling the discs, so it pretty much became muscle memory. I saw you had the same thoughts initially in your thread on the switch but was not sure if you had tried to change anything.
    Millermatic 252 MIG
  11. #8
    Flip the switch handle over if it will and almost accomplished the same thing unless it is keyed to that position which it may be.
    I guess though it isn't even the markings you want fixed but rather clockwise on switch equals clockwise on the quill.
    Did it come with a schematic. Check out what the drum switch is doing thoroughly first. Sure don't wanna fry something.
  12. Likes psacustomcreations liked this post
Page generated in 1,603,162,091.87333 seconds with 12 queries
