Results 1 to 15 of 15
Thread: 3 Phase motor stalling
    Nov 2014
    Southern CT
    The 1hp 3 phase motor on my lathe, (1948 South Bend 13) stalls occasionally. This is with light cuts, easy feed in on parting cuts, nothing I ever had a problem with previously.
    So the question for those with electric motor experience is:
    Why does that happen, or is this motor showing signs of eminent death?
    Ernie F.
    Oct 2019
    Australia
    Re: 3 Phase motor stalling
    Either a loose connection on one ohase, voltage drops from supply, or a bearing seizing up.
  3. Likes William McCormick liked this post
    Is it hooked up to 3 phase power or is it running from a converter. In general a 3 phase motor will run at greatly reduced power on 2 phases. It is common for a thermal overload or a fuse to be not working on one phase. Most of the ones I have seen that this has happened on you can tell by one or more of these signs. 1.reduced rotational speed , 2 a louder hum from the motor , 3 the motor runs hot. Check power at all 3 wires to the motor.
  5. Likes CAVEMANN, docwelder liked this post
  6. #4
    Nov 2014
    Southern CT
    Quote Originally Posted by Woznme View Post
    I’m beginning to suspect the F-R drum switch as possibly worn, dirty or otherwise faulty.
    Ernie F.
  7. Likes William McCormick liked this post
  8. #5
    Nov 2014
    Southern CT
    It is hooked to true 3 phase service, no converters. I checked the voltage with a meter at the main service and at the twist lock outlet that feeds the lathe. Averaged 240 volts across any pair of the outlet contacts.
    i did lose a phase a few years ago when a squirrel toasted himself up on the service pole. The lathe and the mill wouldn’t even run with that phase knocked out.
    i will check at the motor and the switch.
    Ernie F.
  9. #6
    San Jose, CA Kelseyville, CA
    Also might try checking continuity between windings with the power off to see if anything funny is going on between them. You should get no continuity.
  10. #7
    Mount Tabor VT
    Take the belt off. With it running, check amperage each phase. If you have the know how to do it safely, check voltage on each phase to ground while running.
    Turn it off, lock out the power source. Depending on whether it is dual voltage. Make a diagram of the way it was connected. You have three or six windings. They will be connected series, high voltage, parallel low voltage. Three windings may be connected at one end internally. three others will have both ends in the wire box.
    With an ohmmeter, or better still a megaohmmeter, you are looking to compare the windings. Three interconnected you can only check two at a time. check each combination of these, compare. The three double ended, compare.
    Check each lead for continuity to the motor frame.
    A difference in the winding resistance suggests winding problems. A difference in voltage says power source issues. Current difference might be either, or both.
    Three phase motors are subject to damage if all three legs of supply aren't equal or close to it.
  11. Likes ronsii, docwelder liked this post
  12. #8
    Jun 2011
    Aiken SC area
    Is the belt slipping? Might need some spray grip if it is. My belt was leather. Bob
  13. Likes William McCormick liked this post
  14. #9
    Check the drum switch.
    Typically this where you find the problem on old tools .
  15. Likes William McCormick liked this post
  16. #10
    Jan 2020
    Metalman. Did you say 240 volts, should be around 277 a-b,a-c,b-c, ground to leg should be 480.
  17. #11
    Jan 2020
    Sorry I got those numbers backward,
  18. #12
    Jan 2020
    Oops, now guessing you got 3 phase 240. Got to get new meds or more booze.
  19. Likes docwelder liked this post
  20. #13
    Check prices for Drum switch on Amazon.
    Drum switch can be rebuilt but it is hard to over the internet.
  21. #14
    Nov 2014
    Southern CT
    I removed the cover from the drum switch and inspected. Didn't look bad or burned, I cleaned the contact surfaces with carb clean and grey Scotchbrite. Have to see what happens on the next job.
    I scored a spare motor (cheap) for this lathe years back and I thought that would guarantee the original motor would never go bad!
    Thanks for all the tips. I'll update this post with any results.
    Ernie F.
  22. #15
    Nov 2014
    Southern CT
    Quote Originally Posted by rhunt View Post
    you
    I think you called it. The belt lacing was giving up, nylon/rubber belt is still good. I trimmed the ends and installed a new lace connection, reinstalled and adjusted. I'll see next job soon.
    Ernie F.
Page generated in 1,603,256,371.93178 seconds with 12 queries
