Results 1 to 13 of 13
Thread: 220-Volt 50-Amp Extension Cord
    Apr 2020
    I'm looking into either a 25-foot or 50-foot extension cord for a Lincoln Power MIG 255. There are plenty on Amazon or eBay. But I noticed they all use 8-gauge or 10-gauge wire. Will that be a problem? My 220-volt outlet uses 6-gauge wire from the electrical box to the outlet. Will the lesser gauge on the extension cord limit the electrical current?
    Sep 2008
    Dalton, GA
    Re: 220-Volt 50-Amp Extension Cord
    There are several good threads on extension cords.
    Here is one:
    https://weldingweb.com/vbb/showthrea...extension-cord
    Here is another:
    One of the electricians can offer more specifics if these don’t answer your question. I believe because of the derating allowed for welders you could use the 8 gauge up to 50’ with no problem, but wait for one of the professionals to confirm.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Miller Thunderbolt XL AC/DC - sold
    Hobart Handler 120
    10FtDrillBit.com
    MyWelds.com
    8 gauge wire will be adequate.
    Apr 2013
    I found a 50' 6-gage used boat cable for my melding cart. And also another 50' 4-gage used boat cable for a separate extension cord.
    The heavier the wire--the lower the voltage drop.
    Laredo, Tx
    I agree. Wire can be de-rated due to the duty cycle of the machine. So you'd be able to pull 50A through 8 gauge because whatever heat builds up, will be dissipated once you hit the 40% duty cycle of the machine, so both the machine and wire would be cooling off. That said 6awg or thicker would be better because there is less voltage drop. The less voltage-drop you get, the better.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    I run a 6ga drop cord for the welder. It's plenty of capacity, AND I can use it to run two 5000w heaters in the shop. Never envisioned running heaters with that cord, but sure enough..........it came in handy. Bigger is better, because you really never know what you'll be doing a few years down the road.
    Jul 2016
    Midwest
    I've used 30' 8ga cords alone and hooked together coming off of a 100 amp recepticle. Never had an issue during "General" welding. Never tried on anything over 1/2". 6ga is good but you start getting into Horse c--k size to wrap up
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
    Nov 2013
    NW New Jersey
    I'm pretty sure it would work fine, but the specs just look odd...
    https://www.amazon.com/dp/B07CJHRNXN
    100% PVC on Jacket, 100% copper in conductor
    Imported
    UL & cUL approved and Listed, Heavy-duty for Welder, 100% copper conductor inside.
    Welder 3-prongs NEMA 6-50 lighted connector right-angle, 50 Amp / 250 Voltage.
    STW 8AWG/3C stranded wire extension cord, support max 40 AMP overload, Max Rate 10000 Watt (250V).
    Molded with electroplate copper terminal in order to avoid surface oxidation effectively.
    Universal to All Other Brands 6-50 Welding Machine 3-pole. Length : 25 FT (25 Feet).
    I think the 40 amp overload Max rate 10000watt 250v is their way of getting around the 6AWG .
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Morton, Washington
    +1 farmersammm. I don't de-rate my extension cords either. If I grab one with 50A ends I expect it can handle it. They may be originally for a welder but needs do change. I de-rate welder connections in the shop and they are labeled and dedicated as welder only. That said, you'd be fine with 8 gauge, just label it welder only. Now if your welder is 100% duty cycle... de-rating become a mute point.
    Of course we've all likely scabbed something together way sketchier in a pinch.
    Oct 2018
    I'm no electrician, but I researched sizing extension cords recently and here's what I came up with:
    - Understand how much current your welder draws
    - Size the circuit breaker to the welder
    - Use building wire and an outlet sized to the breaker that protects it
    - Size the extension wire gauge to the length and current draw required (or larger, but never less than the breaker)
    Voltage drop is important. I found 8-gauge cords of 25 or 50 feet were good up to 30A before voltage drop exceeded 3%. 6-gauge easily handles 40 & 50A loads. More here: https://welditu.com/gear/safety/what...xtension-cord/
    WelditU.com
    Lincoln Weld-Pak 140HD
    Hobart Handler 140
    May 2017
    The electrical wire in your walls going to your outlet is 6 gauge so it does not overheat and catch your house on fire. It also might be longer than 50 feet from the electrical panel. More wire means less likely to have voltage drop.
    Extension cords are out in the open. If they overheat it wont be between walls where you cant see the fire. It is only fifty feet so voltage drop is not likely. If you do have unacceptable voltage drop, you simply buy a heavier cord. If the wire in your house had a significant voltage drop and you went to upgrade your wire, you can imagine the cost and labor for that would be high.
    Lititz, PA
    A minor point to add to this: get a garden hose hanger to put on the side of your cart or near the outlet you will be plugging into. These cords are HEAVY and it gets REALLY ANNOYING.
Page generated in 1,604,021,283.57123 seconds with 11 queries
