Results 1 to 8 of 8
Thread: Ellis saw maintenance
    May 2016
    Southern California
    Starting a new job tomorrow, they have a horizontal bandsaw growing dust. Claim to have replaced all bearings and guides but can't get it tracking correctly for more than a cut or two. Will look it over soon and report back if I see anything obvious. Wanted to get a thread started, maybe somebody who has been down that road will offer some advice.
    Miller Multimatic 220AC
    Miller Thunderbolt 225
    Victor OA
    Sep 2015
    West coast of Florida
    Re: Ellis saw maintenance
    These 2 sites have good resources for trouble shooting
    https://www.sawblade.com/
    https://www.bandsawbladesdirect.com/...awing-problems
    Richard
  3. Likes psacustomcreations liked this post
    First thing is usually the blade. An Ellis saw does not use coolant so that could be an issue. Generally Ellis saws have no issues with blade tracking once it's adjusted correctly. The blade cutting out of square vertically is a more common issue.
  5. Likes tapwelder liked this post
  6. #4
    visit their website. call ellis.
    as stated. check blade and once adjusted, it tracks properly. The routine tracking adjustment on the 1600 is simply appropriate tension, and that is not a blade as tight as you can get it.
    They have helpful videos on their site.
  7. #5
    May 2016
    Southern California
    Thanks LtBadd, I will check those sites.
    MJD, cutting out of square vertically sounds like maybe what they were describing.
    tapwelder, that has been my experience with most bandsaws. Sometimes I tune them to the appropriate 'twang' other times crank up overly tight, roll them through a few revolutions by hand and then back off a scosche. Will see what the Ellis site has to say, maybe a more definitive technique is called for.
    Victor OA
  8. #6
    Sep 2005
    Cave Creek AZ
    Put in a new blade, make sure it is the right size and pitch. I like the 6-10vari tooth.
  9. #7
    May 2016
    Southern California
    First day on the job, might not have time to check the blade today. Good advice on the vari-tooth saw blade walker, thanks!
    Victor OA
  10. #8
    May 2016
    Southern California
    Looked at it briefly today, it is an 1100. We have new blades on the shelf, 14 tpi. The counterweight spring looks overstretched so it may be difficult to set the "weight". I am expecting 8 pounds with the hydraulic valve wide open. Will put a scale on it when it rises the priorities list, maybe next week.
    Victor OA
Page generated in 1,603,715,958.38466 seconds with 12 queries
