Results 1 to 8 of 8
Thread: Thermal Arc and Lincoln Mig Whips?
    Dec 2011
    Do Thermal Arc and Lincoln mig welders share the same style back end that plugs into the welder?
    Re: Thermal Arc and Lincoln Mig Whips?
    Would need to know which specific machines. Some Lincoln have a special Lincoln plug and some use a Tweco plug. Thermal Arc might be Tweco but not sure.
    Jul 2016
    Midwest
    Lincoln has 2 back ends. Tweco #4 and their own that is similar but larger diameter. They are switching back to the Tweco # 4 style. Thermal Arc And Tweco are both Thermadyne/Victor brands and the guns are the same.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
    Hi. I use my 180 Tweco mig gun Between My Lincoln 180 mig And My Thermal arc 181i Works Perfect.
    No alterations needed.
    Dec 2011
    Josey......what about the small connector? Are you saying that the small connector works between the Lincoln 180 and the TA 181I?
    Hi. Enter Tweco rear connector plug no 350174H that seems to be standard on Lincoln and thermal arc. I see you can buy them cheaper on Amazon.
    Dec 2011
    Jonesy i was referring to the very small connector that works off the mig gun trigger.....is this switchable between both machines?
    Yes they are. 2 pin doe's the mig 3 pin for the spool gun
Page generated in 1,604,172,724.77369 seconds with 11 queries
