Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
Thread: Mig will start an arc but has almost no heat
    Re: Mig will start an arc but has almost no heat
    So, that is the gas line at the power lug.
    Soda springs,Id
    If it has connections for gas then maybe that's the only way to run it.
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Yep....
    Jul 2020
    Yes, that is the gas line
  5. #30
    Jul 2016
    Midwest
    I'd try the stickout from tip to work like we had mentioned. If that's not it and polarity can't be changed and you were ok with fluxcore then maybe rent a 5# CO2 tank for low cost to test the machine before you jump all in with 75/25.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
  6. Likes William McCormick liked this post
  7. #31
    Jul 2020
    Got some CO2 gas and wire, this is the best I could do...didn’t get the frying bacon sound more of a rapid popping like a machine gun. I played a bit with the heat and wire speed
  8. #32
    Ceres, California
    See if you can find the model number printed on the welder case.
    It will be near where the welder specs are printed.
    I am guessing it will be 117-001 through 006. If so your welder is MIG only.
    Positive on the wire and must use gas.
    Model number will start with 117-.
    You can go to Lincoln electric's web site. Pick the support tab then find parts.
    Then guest. enter the model number in the code number box. wait for a selection to show up and select it.
  9. #33
    Ceres, California
    if your welder is a 100 amp welder it will not weld .035 mig wire.
    use only .030 or .024
  10. #34
    Jul 2020
    it is a 117-003 welder. I got gas .030 wire, and tips. It is better but not right.....figured out the potentiometer for the wire feed is all over the place. 70 inches per minute to 580 in one step up on the dial. Locating the part now....bet it runs right when the wire speed is correct!
  11. Likes William McCormick liked this post
  12. #35
    Laredo, Tx
    Quote Originally Posted by Legacy37 View Post
    we figured out the potentiometer for the wire feed is all over the place.
    there
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  14. #36
    Ceres, California
    New pot should help. Lets hope it is not the control pcb.
    Just for kicks, clip you dc meter to the drive housing and the other clip the the contact tip. run out about 2 inches of wire. trigger welder read the voltage drop across the miggun. a good gun will read less than 1 volt. a bad gun will read over 15 volts. gun is pulled apart and weld conductor is open, only the liner is carrying current. Unfortunately there is nothing helpful on the Lincoln web site.
    Try calling 1-866-236-0044 this is tech support for century products, new and old.
    They should be able to e-mail you manuals for your machine.
    might have it on my old computer but it started a virus scan and can't use it until it is done several hours from now.
  15. Likes Rondo liked this post
  16. #37
    Laredo, Tx
    Definitely need to work on CTWD. That's what, about 2.5 inches?
    Sorry Legacy, you need to watch some good beginner videos on MIG/flux core welding, preferably from Weldint Tips & Tricks on Ebay. Very reliable source.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  17. Likes ronsii liked this post
  18. #38
    May 2012
    Ontario, Canada
    I was trying to run a bead on a piece of 1.5Ē angle iron, it currently has flux core in it (has regulator and valves for gas they seem to be working sonít want to spend $$$in a tank if this thing is a boat anchor) I cannot find polarity or a way to change it.
    If it was set for solid wire mig with gas and you are using it with flux core, the polarity is wrong.
    It's usually a matter of bolting and unbolting wires inside the spool panel.
    Download the manual, read it twice
Page generated in 1,603,253,894.18307 seconds with 13 queries
