Results 1 to 16 of 16
Thread: Box and Pan Break question
    Jan 2012
    I have a chance to buy this Chicago box and pan brake for 3500 dollars. Very little use. It is 4 foot and bends up to 12 gauge. Im wondering if I will regret buying this 4 foot model rather than getting a 6 or even 8 foot model. I was considering a Baileigh which I don't believe is as good as the Chicago I'm looking at plus the Chicago is local. Have any of you folks bought the 4 foot model bender and regret getting something longer. I do some fab work but mostly farm machinery repairs and machining. thanks Paul
    Re: Box and Pan Break question
    Any wider than 4' will take some serious muscle to bend 12 gauge, even 14 gauge. It mainly comes down to your intended uses. If you need wider material bent your probably better hiring it out, unless it's a constant thing, and then a brake press would be a better choice.
    Only you can decide how big will work for you. Chicago is a very good brand. Everybody always wants bigger but do you have room for a 15' wide 3000 ton brake?
    Jun 2008
    New Plymouth ID
    I just purchased a powered 8 pan and box but it was way more money than that. I would have got a 4 for that price if i could have found one local. They are never big enough and never bend thick enough mine will do 10 gauge so of course i want to work 1/4, But a 4 sure would be a handy size for most things. And doesnt take 140 square feet of shop space
    Fredericksburg, VA
    I have used the 6 foot manual version of that break. As MJD mentioned, it takes a lot of power to bend the full width with thicker material. In one instance, there were two of us lifting to make a couple of bends.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
    Jan 2012
    thanks for the comments folks. Idacal what hydraulic model did you end up with and how much was it if I could ask. thanks Paul
    Sep 2005
    Cave Creek AZ
    I have that machine. I use it regularly. It is a bit pricey for it, but it is a good machine. Most longer machines are leaf only until you step up to a press brake. I farm out longer stuff to a press brake shop.
    Jun 2008
    New Plymouth ID
    Its an old chicago thats all electric, electric motor driving a gear box Turn the motor on to make the Bend then motor off when it hits the angle switch its a model 62 https://www.sterlingmachinery.com/me...s-brochure.pdf
    Sent a pm also
    Jan 2012
    Thanks everyone for your knowledgeable responses
    Paul
    Dec 2016
    nice brake but priced a bit high.
    as others have said, 4ft may be too little for what you will do. i have one and wish most of the time i had 6 or 8 ft.
    Quote Originally Posted by idacal View Post
    Sent a pm also
    Old brochures are so much better than the new ones. Never knew Chicago made so many different types of brakes.
    Jan 2012
    Just thought I would let you all know that I ended up buying the brake. Got it for 3000 dollars. still a lot of money but all the dies were there as well a one full length one if I wanted to use it as a full pan brake. thanks Paul
    Mar 2015
    Be advised that with the angle on the apron removed the capacity is reduced by at least 2 gauges. Standard is to set the top leaf back by twice the material thickness. If you run out of a$$ to make a wide bend, setting it back even further will reduce the effort required. Do not use the forklift to complete a bend you can't pull and expect to have a good brake when you finish.
  14. Likes idacal liked this post
  15. #14
    Jan 2012
    Bent, now that's some good information. I appreciate that as I had no idea on how to set up the machine properly. I will have to see about getting a manual for the company. thanks Paul
  16. #15
    Weiser Idaho
    Don't suppose you bought it from north Idaho did you?
  17. #16
    Jun 2008
    New Plymouth ID
    Yea thats the one, then drove 800 miles To pick it up But thats the way it is i guess When we live in this section of the country.
Page generated in 1,603,315,239.71812 seconds with 13 queries
