Results 1 to 3 of 3
Thread: Ranger 250 problem
    Apr 2011
    minnesota
    Ranger 250 problem
    Hey guys we have a ranger 250 engine drive welder that developed a problem. A few weeks ago it lost weld output only had a faint arc. Sent it I. To a lws that does in house repairs. They load tested it and of course it worked so they suspected leads were bad. Get it back put new leads on it seems to work but for only 5 rods. Weld output drops way down but still has auxiliary output. If it sits overnight it will work again. Any thoughts? I am thinking circuit board but that’s a expensive part to throw at it hoping it works. Thanks
    Millermatic 252
    millermatic 175
    miller 300 Thunderbolt
    lincoln ranger 250
    smith torches
    lots of bfh's
    Oct 2008
    Madison GA
    Re: Ranger 250 problem
    Look at this service manual for trouble shooting
    https://www.manualslib.com/manual/95...-A.html#manual
    I've been working on a Ranger 250 with no weld output but had had AC power. Ultimately found the diode board attached to the chopper board was shorted that caused chopper board failure. If you need a board good luck. Most are no longer in production and most Lincoln board can't be repaired because of potting. Anybody got a chopper board for one of these?
    Kirby
    Apr 2011
    minnesota
    Thanks for the reply. I am gonna send it back to the shop with the additional info I figured out. Hopefully figure something out
    Millermatic 252
    millermatic 175
    lincoln ranger 250
    smith torches
    lots of bfh's
Page generated in 1,713,244,056.44419 seconds with 17 queries
