Results 1 to 2 of 2
Thread: Used Ironman 230 whatís it worth?
    Jul 2020
    Indianapolis
    I found an IM230 supposedly little use (stated only used three times). Itís a 2 hour drive, heís asking $950, hoping to get it for $850, what do you think is reasonable? I know the 230 is now discontinued and the 240 is out. Can this machine run .023 wire if I need to at some point?
    Thanks guys!
    Sep 2016
    Detroit, Michigan
    Re: Used Ironman 230 whatís it worth?
    Quote Originally Posted by kent_man View Post
    I found an IM230 supposedly little use (stated only used three times). It’s a 2 hour drive, he’s asking $950, hoping to get it for $850, what do you think is reasonable? I know the 230 is now discontinued and the 240 is out. Can this machine run .023 wire if I need to at some point?
    Thanks guys!
    The manual lists a .023 roller, and the specs shows settings for .023 wire, so you should be good there. Several of the local Tractor Supply stores show them still being in stock for $1,499...not sure if they're closeouts or not.
    Generally speaking, around half of new is the ballpark price for a decent used machine and more if it's super clean.
    http://mivise.com
    Millermatic 252
    Miller Dialarc 250
    Everlast PowerTig 210EXT
Page generated in 1,596,741,589.41189 seconds with 12 queries
