Results 1 to 3 of 3
Thread: Mig Max 215
    oh10
    Mig Max 215
    when using c25 is the gas flow supposed to shut off immediately after you release the trigger or should it flow for a second or two before shutting off.
    Thanks
    candyman
    SoCal-LA
    Re: Mig Max 215
    Quote Originally Posted by candyman View Post
    Thanks
    Typically shuts off when the arc does. Would not bother me for a second or 2 of post flow though to keep the wire stub clean.
    Jul 2016
    Midwest
    Re: Mig Max 215
    Most of the smaller machines have a couple second post flow now days. It's designed for those who weld stainless. Nothing hurt on the other processes except a few cents worth of gas out of every tank. Also if your burn back isn't turned up more than needed, Post flow can help keep the wire ball to a minimum.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
Page generated in 1,603,703,519.49746 seconds with 11 queries
