Results 1 to 17 of 17
Thread: BBQ Grille Grates
    Apr 2020
    BBQ Grille Grates
    I needed new grates for our Wolf BBQ362-2. I refuse to pay near $700 for new grates.
    Welded only the end rods and the middles all float. Used 1" bar stock for the end rails and 3/8" rod for the grate, all hot rolled A36. Supplier only sells 20' sticks. Used 3 sticks of grille rods and have almost 14' leftover of bar stock. Rods were $7 each and the bar $47. Then taxes, a $15 handling fee(?!), and $88 later...
    Split the grate in two to make it easier to handle. Cut the rods and bars to length, beveled the ends, sanded one edge of the bars free of mill scale, used black Sharpie to show layout lines, used Starrett spring punch for the first time, drilled pilot holes followed by final hole size, scrubbed parts in hot water with Dawn soap, thru all parts into blast cabinet to remove all mill scale, fitted assembly and checked for overall dimensions and square, then welded the end rods, and lastly put it on the grille with vegetable oil to season.
    Now to put the grille back into proper use.
  2. Likes motolife313, bfjou812, Equilibrium liked this post
  3. #2
    Apr 2020
    Re: BBQ Grille Grates
    More pictures
  4. Likes labparamour, frieed, shortfuse liked this post
  5. #3
    Mar 2005
    Under a Rock
    Looks good
    I built something very similar for my smoker only because I hate the look of expanded metal for cooking surface.
    If I ever do it again I will use stainless.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  6. #4
    Jun 2009
    Draper, UT
    I make charcoal baskets for my Big Green Egg cooker. The first couple were 3/16 mild round bar and didn't last too well.
    The latest is stainless and is unharmed after 2 years of heavy use.
    MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC, victor Oxy/Acet
  7. Likes Shootr liked this post
  8. #5
    Aug 2012
    AR
    Good job on the gas grill grill
  9. #6
    Apr 2020
    Thanks for the replies.
    I toyed with the idea of stainless for about 2 minutes, but then did not want to fool with proper MIG gas, wire, etc.
    I have a Lincoln ProMig 175.
    The expanded metal was a band aid that limped thru for around 4 years.
  10. #7
    Oct 2013
    Long Island, NY
    Looks good. Nice job.
    www.FirehouseFabricators.com
    Zach
    Millermatic 255
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
  11. #8
    Jan 2011
    W. Wisc
    Came out nice! I was in a similar boat with my Weber and didn't want to spend $100+ on replacing the rusted out grills...but I also had leftover 304SS rod from an earlier project, so pull out the TIG and voila! I also had them electropolished as it was the same $75 min charge for EP or just passivating
    Name:  Grill fabrication (Large).jpg
    Name:  Grills complete (Large).jpg
    Name:  Grill_completed (Large).jpg
    -Dave
  12. Likes Equilibrium liked this post
  13. #9
    NW New Jersey
    Quote Originally Posted by frieed View Post
    304 or 316 stainless steel ?
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  14. #10
    Mar 2005
    Under a Rock
    That came out great.... Ima need to do the same thing soon.
    Did you also make the "flavor bars" ? Those look new also....
    Hypertherm PM 45
    HTP 221
  15. #11
    Jun 2009
    Draper, UT
    304 .
  16. #12
    Nov 2014
    PDX PNW
Size:  76.9 KBName:  23CF37BB-6999-4BED-8AFE-CDB5BDFF045D.jpg
Size:  92.2 KBmore ideas for anyone
  17. Likes docwelder, Equilibrium liked this post
  18. #13
    Big Lake/Monticello MN
    Grills came out great - nicely done
    Syncro 350
  19. #14
    Jan 2011
    W. Wisc
    Yeah I forgot about those. That was leftover 14ga 304. It was way too stiff for me to bend with my limited equipment, so I had a shop with a bigger press bend them.
    Rods were 5/16" for the main grate but the cross bars below are 3/8" The 2 smaller grates are 3/16"
    -Dave
  20. #15
    NW New Jersey
    304 .
    I have quite a bit of leftover 304 I'd like to use for something similar. At first , before I read the caption, I thought it was a fryer basket.
    Thanks
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  21. #16
    Arizona
    Finally a SS project I can do to practice with my lift tig. I need grates for my old Turbo grill and for SS they want a lot of dough. Now to look for some 304.
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
  22. #17
    Mar 2007
    MidWest
    OP and all. I will keep this in the archives for later. All nice work.
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Ranger 8 Kohler 20HP
    Victor/Harris O/A
    K 487 Spool Gun
Page generated in 1,713,288,518.83629 seconds with 19 queries
