Results 1 to 25 of 37
Thread: 60 INCH Mechanical Shear
    Hereís something I just had to share. Due to nothing but sheer luck, this morning I was able to save this electric shear from the scrappers.
    It hadnít been used in years and a local marine fabrication shop needed the space, pushed it outside and scheduled the scrap truck to pick up the next day.
    So ... $300 CA dollars later ($224.28 usd) and under an hour round trip, I had it home.
    Nice overall shape for a 48 year old Made in China machine. Blade has no nicks but needs sharpening.
    60 inch width of cut.
    3/16Ē aluminum, 1/8Ē SS capacity
    5500 pounds 3 HP 3 phase
  2. Likes 12V71, psacustomcreations liked this post
  3. #2
    Dec 2016
    Re: 60 INCH Mechanical Shear
    great deal. congrats.
    Quote Originally Posted by filetobeef View Post
    Thank you, filet!
    Apr 2016
    I like the "no cutting flat bar" sign... must be for that guy who uses wiss snips to cut wire.
  6. Likes 12V71, kmar35 liked this post
  7. #5
    Quote Originally Posted by Weldalittle View Post
    Or the moron who uses a transfer punch as a drift.
  8. Likes 12V71 liked this post
  9. #6
    Fredericksburg, VA
    Congrats Terry.
    Do the blades flip over? At least on my stomp shear, they flip over so it may be that yours can flip over and that side may be in good shape or better shape.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  10. #7
    Sep 2005
    Cave Creek AZ
    Nice score!
  11. #8
    Congrats Terry.
    I havenít had a chance to look yet Pat. I assume they do flip.
  12. #9
    Nice score!
    Thanks walker!
  13. #10
    Or the retard that cuts rebar in an ironworker flat bar shear. That one was sprung so far out of alignment it was basically junk, they also had a 10' hydraulic 3/8" plate shear that had so many chunks out of the blades it couldn't cut an 8' sheet of 10 gauge. If I owned that equipment I would have shot the knuckle dragging, mouth breathing dips**ts that treated that stuff like that. Management just kept buying new stuff for the baboons... Pathetic.
  14. Likes Lis2323, MinnesotaDave, ronsii liked this post
  15. #11
    Sebeka and Bemidji MN
    Really nice score
    Airco 300 - Syncro 350
  16. #12
    Looks like your first project is making a belt guard. Do you know if there are any problems with it?
  17. #13
    The foreman said the shear was in working order but ďin need of maintenanceĒ and it sat unused because the owner was too cheap to address it.
    Iím quite certain they had a bigger newer one in their shop.
    It came with the belt guard. Doesnít even require body work.
  18. #14
    Nov 2012
    new york city
    get your story straight for when the cops show up. that was a steal!
    i.u.o.e. # 15
    queens, ny and sunny fla
  19. Likes ronsii, forhire, lotechman liked this post
  20. #15
    Heh heh. They loaded it for me too.
    I didnít even have to drop my forklift off the truck.
  22. #16
    So sweet! Congratulations on the steel of the year!
  23. Likes ronsii liked this post
  24. #17
    Thanks V. Iím kind of embarrassed though. I just had a thought and double checked. When I first unloaded it, I measured the bed width which is 60Ē but the width of cut is actually 52Ē.
  25. #18
    Well that's it, haul it off for scrap.
  27. #19
    Too traumatic. The poor shear was saved from the scrapper just last week.
    Iím getting soft in my old age. It can stay....
  28. Likes ronsii liked this post
  29. #20
    I’m getting soft in my old age. It can stay....
    You know.... they have pills for that LOL!!!!
  30. Likes Lis2323 liked this post
  31. #21
    Fredericksburg, VA
    Thanks V. I’m kind of embarrassed though. I just had a thought and double checked. When I first unloaded it, I measured the bed width which is 60” but the width of cut is actually 52”.
    In that case, I will give you $350 in Canadian for it since it didn't live up to its advertising. You make a quick profit of $50 and clear up space for a real 60" machine.
    Millermatic 252 MIG
  32. Likes Lis2323, ronsii liked this post
  33. #22
    Yours are BLUE, right ??
  34. Likes psacustomcreations, ronsii liked this post
  35. #23
    Miller pills!!! BIG blue
  36. Likes Lis2323 liked this post
  37. #24
    Gotta love this forum. Good friends looking out for each other and always willing to help out!
    Thanks for the offer Pat, but Iím good.
  38. Likes ronsii liked this post
  39. #25
    I might not get around to setting up the shear until the winter but I thought I should take advantage of the good weather to degrease and wash the underside.
    I scoured the surface rust off a spot on the blade and it is indeed flippable. There is at least one good edge available for sure so that is good news.
    With a little bit of luck it will only require cleaning and set up.
  40. Likes ronsii, psacustomcreations liked this post
Page generated in 1,603,315,764.27316 seconds with 12 queries
