Results 1 to 7 of 7
Thread: Crown Alloys Royal 300 aluminum electrodes - anyone ever run them?
    Jul 2020
    My usual supply place had a box of these - Crown Alloys Royal 300 - aluminum electrodes so I got a pound of it to try. I don't have any projects with aluminum right now, but I have done quite a bit of aluminum sheet metal work over the past 5-10 years and have scraps to practice with. Any tips on running them?
    The current doesn't seem very high - 50-100 amps for 3/32", DCEP.
    Jun 2011
    Aiken SC area
    Re: Crown Alloys Royal 300 aluminum electrodes - anyone ever run them?
    I have welded with some stick aluminum rods in the past, not too pretty but in a pinch will get the job done, just not pretty. There's been tests done here on occasion with aluminum stick rods so a little search should get you the results. Best of luck, Bob
    I've done a little stick aluminum, either 1/8 or 5/32, the biggest issue was the NASTY white flux, it smokes badly and is very hard to clean off after welding , kind of reminded me of melted brazing flux.
    NRA LIFE MEMBER
    GOD BLESS AMERICA!
    RONALD REAGAN
    NW New Jersey
    You may want to practice a little before you need to use it for an emergency repair. It runs a little different than steel rods. It burns hot , fast , and smokey. it would be a good idea to find some scrap to practice on first.
    The spec sheet doesn't say much about the chemistry of this electrode, but it isn't made for critical welds, mainly for simple repairs. It also recomends a cleaning method , and preheating before welding. Let us know What you think of it after you try it.
    Best of luck
    Snap-On YA-212
    Lotos Cut60D
    NW New Jersey
    Best of luck
    Oh,I forgot... here's the tech sheet for Royal 300 welding rod, http://www.crownalloys.com/TechSheet...White)_PWP.pdf
    Snap-On YA-212
    Lotos Cut60D
    Jul 2020
    Thanks for the replies. All I have right now is some scrap aluminum to practice with. Nothing critical anyway.
    As to testing - my machine is in pieces at the moment and will be getting a new paint job hopefully later this week. If the weather and clock cooperate I am hoping to get things put back together by the weekend.
    Jul 2016
    Midwest
    One of the secrets to running aluminum electrodes is to try to run them at a 90 degree angle or close. They like to arc blow if you tilt them much at all. Prepare to travel at hyper speed too. Also make great oxyfuel brazing rods.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
Page generated in 1,597,046,166.48758 seconds with 12 queries
