Results 1 to 21 of 21
Thread: Paint.... What to go with?
    Jul 2020
    First off, I found a thread (linked right below) on here spanning quite a number of years but there are a lot of paint codes spelled out in the thread (spectacular info!)
    https://weldingweb.com/vbb/showthrea...is-Lincoln-Red
    My question is what kind of paint/process to go with.
    I have another thread going on a 1966 round top idealarc 250 here so that is the project.
    Powdercoating has come up in a few places as being a good option. What I don't like about it is there are info labels/schematics on the inside of the wiring access door that I don't want to loose. So if I used a type of spray paint or brush on paint, in theory, I could retain the labels by protecting them.
    I am not out for an absolutely perfect finish, but I don't want caked on paint that runs. I just want a nice finish that is durable.
    Thoughts?
    The guy that painted mine used rustolium w/hardener
    Came out good.
    1961 btw.
    Jul 2020
    Re: Paint.... What to go with?
    Came out good.
    1961 btw.
    Hey! Not to hijack my own thread... but that's a nice compressor. I'm looking for a 60gal or so. I've been browsing the used market, but I've seen those Quincy's at a few places and appear to be quite high-end compressors. They make screw compressors too.
    The welder looks pretty good. Is the knob bare metal with clear coat? Or was that painted also?
    Keep relative info in one thread instead of multiple threads for basically the same thing.
    Hey Dave why donít you mind your own business.
    You seem to be lately replying to every single thread with your infinite knowledge.
    Why donít you take a breather dude.
    If youíd like to become a moderator why donít you contact ZAP.
    Somehow I donít think thatís gonna happen.
  6. Likes FlyFishn liked this post
    The adjustment knob is bare metal I will try to dig up the thread where the guy restored the whole thing.
    It was a few years ago but he did an outstanding job/took the whole thing apart polished every contact
    Etc. etc.
    I will find it itís here somewhere he also details the paint he used.
    The compressor I bought from Northern tool.
    Iíve been very happy with it.
    I will get you the information on that also when I get a chance.
  8. #7
    I use oil base paint
    John T is right with the Rustolium
    I use Rustolium a lot over years and has worked great
    I if gasoline type welder automotive paint is better for outdoors. I does better job in sun light.
    Powdercoating I have had fall off the metal in big chunks.
    Thoughts?
  9. #8
    Mar 2009
    Thatís weird. Powdercoat Iíve dealt with is the hardest stuff Iíve ever seen to get off.
  10. #9
    Jul 2020
    Thanks for all the replies.
    I am investigating automotive paint locally. I made a trek to NAPA for some other stuff today and talked with the guy there that knows paint. He said they may be able to cross-reference Sherwin Williams paint codes so I dug in to the thread I linked to in the first post. They were not able to pull up those codes. He did search with "lincoln welder" and it came up with 3 colors, one labeled "Lincoln Red". We are not able to see a code for any of them or get a sample. A pint of the paint is about $65-68, I forgot to write it down exactly. A quart is $118. Then the paint needs a reducer that is $30/quart (2 parts paint to 1 part reducer, I think... maybe I have that backwards - I've never mixed paint like this before).
    There is a Sherwin Williams place on the east side of town that deals with auto paint. I will be over there tomorrow so I will see about stopping by.
    At the very least I'd like to get a pretty darn close color match and have it be able to be applied with a sprayer. I'd rather not use aerosol/rattle cans of stock colors.
    Powder coating may still re-enter the picture. The paint dude at NAPA said that good powder coat outfits can lift diagrams/info sheets. I will investigate that a bit.
    When I made the mount for a big shortwave antenna on my truck (2.5" square tube about 30" long and a 1.25" diameter pipe about 18" long in an L shape) I paid $80 if I recall correctly. And that was in 2011. I would imagine all the panels for the welder would be quite a bit more than that - just by surface area alone even in the same date range's dollar worth. That would be magnified a bit in today's dollars. Even at ~$150 for paint and reducer plus a paint gun and regulator it might be a better deal just to get the paint gun + parts and do it myself. Then I can do other paint projects later on.
  11. #10
    Jan 2020
    I agree... that stuff is generally a lot tougher than paint
    Sent from my SM-G970W using Tapatalk
  12. #11
    Hey Dave why don’t you mind your own business.
    Why don’t you take a breather dude.
    If you’d like to become a moderator why don’t you contact ZAP.
    Somehow I don’t think that’s gonna happen.
    I'm guessing your response has to do with the fact you get another opportunity to show your machine off. FlyFishin already had a thread started about his newly acquired machine. Is there going to be a new thread for every single question he has about it? Most forums don't like multiple threads from the same person on the same topic. Never knew there was a limit on how often I could respond.
  13. #12
    I know some powder coat is very hard. But I had some that just came off in big chunks.
    When I buy industrial paint it is very hard and will last for ever.
    There nothing like picking up can of paint and have job done in just few minutes.
  14. #13
    Jul 2020
    Does anyone have a more recent paint code for Lincoln Red? Preferrably Sherwin Williams? What I have from the other thread is:
    J22XXR16517P4337 - Red
    That shows from 2006 for gallon sizes.
    Im not sure that is correct?
  15. #14
    Sure. Why not? fly fishin is looking for help so, Stay tuned for some inside shots of my machine... in one of the "other" threads.
  16. #15
    This is the one I bought in 2017
    Very happy with it. I added an hour meter (just because) and an auto drain.... along with filters/regulator etc etc.
    looks like It went up a few bucks... but still a good deal.
    https://www.northerntool.com/shop/to...0475_200350475
  17. #16
    Sherwin Williams will have all manufacturer color codes. You may need to contact a industry Sherwin Williams. Some Sherwin Williams stores do hire the best paint sales people.
    Sherwin Williams can tell you the best paint to use. I purchased thousands of gallons Sherwin Williams for painting for steel hangar doors.
    I paid a high price but the paint work great
  18. #17
    Jul 2020
    I made it over to the auto-specialty Sherwin Williams in town here and the paint codes from the other thread come back to a custom mix from the Garfield Heights, OH location (store code 4337 - numbers in the paint codes). Those are not orderable codes for Sherwin Williams to "mix", it is specific to the Garfield Heights location. I am thinking of calling them to see what I can get that way, but it might be too much hassle and the whole process might be too extravagant and high-priced anyway.
  19. #18
    Some automotive paint can be custom mixed and put in aerosol cans. It is much better than most standard spray paint. Might be a way to get a better paint job for less $$$. Prep is the most important step whether it's welding or painting. You try and rush or cut corners is when you run into problems. You could make it look all old and beat up like it's been through a battlefield with some bullet hole stickers and Miller Killer decals but like new on inside. When people come over, say look what I bought. While they're shaking their heads in disbelieve you should them how nice it welds. Like a sleeper hot rod.
    https://www.amazon.com/Realistic-Bul.../dp/B07JBM3MLY
    https://lincolncontrolplates.com/inc...il/36152/32007
  20. #19
    Jul 2020
    Rust Oleum makes a Farm & Implement line and their Massey Ferguson Red is a pretty close match as best I can tell from the digital comparison. The down-side is that no one stocks it in a quart size container. I can get either a spray/rattle can or gallon at Tractor Supply, or order 2x quarts at Southerlands (min quantity for an order). So it looks like the gallon is going to be the option - then spray about 4-5 coats. Rust Oleum won't be as high-quality as automotive paint, but considering the cost and the rest of the stuff I need (reducer, hardner, primer, etc, etc) I am not sure it is worth the investment. If I have a gallon of this stuff I will have plenty left over for a re-paint at a later date (if the paint is still viable...).
    Name:  paint match.jpg
  21. #20
    Jul 2020
    Well let me ask everyone this...
    What are your thoughts on this color - Ford Red? Compared to the Massey Ferguson Red in the previous post. The Massey Ferguson looks closer to the image color from my picture, but I am thinking the modern Lincoln Red is brighter - maybe closer to the Ford Red here???
  22. Likes timberjack liked this post
  23. #21
    Jul 2020
    Kentucky
    Well, im new here but like your choice with massey ferguson red, its the same color im going with. ha. for my welder . and probably some tool boxes.
  24. Likes FlyFishn liked this post
Page generated in 1,596,653,716.45546 seconds with 14 queries
