Results 1 to 21 of 21
Thread: Squat Rack Lever Arm Attachment
    Oct 2013
    Long Island, NY
    Iím a bit meathead and with the current fitness apocalypse going on I decided to add some pieces to my home gym setup.
    Rogue Fitness charges $900ish for their setup which is admittedly a bit nicer. But, itís $900.
    I designed mine to use a 5/8Ē shaft held in a couple of Oilite bushings. The same way Rogue does it.
    Rogue uses a side pin which my rack does not have holes for so i decided to do a retaining pin on the spine.
    Anyway, hereís my design I came up with and the progress thus far
Size:  82.5 KBName:  5949DE67-C91A-486E-8634-C146DCFDB9B6.jpeg
Size:  78.8 KBName:  3F5BF19D-AA7F-42E1-BA24-C3FD004CF579.jpg
Size:  24.6 KBName:  AEC040F6-6CEC-4D25-97DD-28D00A6C1159.jpeg
    www.FirehouseFabricators.com
    Zach
    Lincoln 210mp
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
  2. Likes ronsii, VaughnT liked this post
  3. #2
    Re: Squat Rack Lever Arm Attachment
    Looks like it'll work
    Oct 2013
    Long Island, NY
    Parts were all CNC plasma cut. The more critical holes were hand drilled.
Size:  121.3 KBName:  7E4C1968-5E08-4D12-A772-430EFA8E0FB7.jpg
Size:  133.9 KBName:  211774E6-DF25-430B-AAD3-918CD55107E8.jpg
Size:  122.6 KBName:  DA280C9C-F530-4948-AC49-480B0562557D.jpg
Size:  163.3 KBName:  EE5DA59D-49B7-4CD6-8588-89DCBDF47FA5.jpg
    Zach
    Lincoln 210mp
    Lincoln SW200
  5. Likes ronsii, VaughnT liked this post
  6. #4
    Oct 2013
    Long Island, NY
    Set up the plasma to cut all the tube holes as well. This was a bit of a learning experience I donít use it for tube much itís tricky to align it.
    Also 3D printed some spacers for the rack to remove wobble. Usually this is done with UHMW plastic but for now Iíll try this and see if it holds up.
    Thatís all i got for now. Iím waiting on 2Ē tube for the plate pegs.
Size:  119.0 KBName:  50836221-F9E0-44C7-A3E2-8AA716BF7641.jpg
Size:  87.8 KBName:  57B4683B-8396-436A-B4EE-368915F216CC.jpg
Size:  80.3 KBName:  353BBF0E-1180-4E03-8C0A-D2ACF828096F.jpg
    Zach
    Lincoln 210mp
    Lincoln SW200
  7. Likes ronsii, N2 Welding liked this post
  8. #5
    Looks great!!!
    What material and infill did you use on the spacers?
  9. #6
    Oct 2013
    Long Island, NY
    Looks great!!!
    PLA 40%
    I don’t really expect it to hold up, it was just easier than ordering UHMW for at least seeing if it works.
    Zach
    Lincoln 210mp
    Lincoln SW200
  10. Likes ronsii liked this post
  11. #7
    PLA 40%
    Gotcha I can't remember but will your printer handle any of the nylon filaments? some of them work really good for that sort of thing... and tough as nails.
  12. #8
    Oct 2013
    Long Island, NY
    I’m not really sure I’ve only used PLA.
    It’s a ender 3 I’m gonna say no.
    Zach
    Lincoln 210mp
    Lincoln SW200
  13. #9
    Oh yeah, you'd have to change your hotend and bed plate as you need 250C+
  14. #10
    Excellent design on the weight rack thing, but those dividers are what caught my eye! You make them yourself? Never seen a set like that before!
  15. #11
    Awesome work! Could you just use UMHW tape to take the wobble out? Or not enough thickness?
  16. #12
    Sebeka and Bemidji MN
    Quote Originally Posted by VaughnT View Post
    Same here, those are sweet
    OP - Super nice job, very clean. Attention to detail is excellent
    Airco 300 - Syncro 350
  17. #13
    Mar 2019
    SoCal
    Man that is some awesome work! I love the fact that you designed it on CAD and followed all the way through, one stop shop. Ten thumbs up!
  18. #14
    Feb 2009
    Coastal NC
    I was going to ask the same question.
  19. #15
    Oct 2013
    Long Island, NY
    The compass is actually one of those Rare times harbor freight knocked it out of the Park...
    https://www.harborfreight.com/6-in-l...der-63659.html
    And the UHMW has to be 3/8” thick. I drilled and tapped the mounts already.
    By the way for the non gym rats this is the end goal
    Zach
    Lincoln 210mp
    Lincoln SW200
  20. Likes N2 Welding liked this post
  21. #16
    Apr 2016
    CA
    Thanks for the link to those compasses.
  22. Likes BrooklynBravest liked this post
  23. #17
    Feb 2009
    Coastal NC
    Thanks for the link and image for the non gym fellas.
    They look great, nicely done.
  24. Likes BrooklynBravest liked this post
  25. #18
    Oct 2013
    Long Island, NY
    Updating some projects.
    I did end up finishing these. They work exactly as intended however I will say they're a bit of a hassle to set up (a lot because of my small space and fear of bashing into the walls)
    Fun project regardless. Nice to do some passion projects here and there.
    Zach
    Lincoln 210mp
    Lincoln SW200
  26. #19
    Wow. They turned out awesome. Totally pro.
    Nice work!!
  27. #20
    Bilbao, Spain
    Awesome! I always wondered how the name brands get by charging soooo much for basic steel tube structures... Did you make a guesstimation to see how much did you put into them? Just to have a real perspective of a pro-job (If I were to do it myself I would basically butcher it freehand).
    Mikel
  28. #21
    Oct 2013
    Long Island, NY
    Quote Originally Posted by Mikel_24 View Post
    Mikel
    Under $100.
    Zach
    Lincoln 210mp
    Lincoln SW200
Page generated in 1,603,957,261.65726 seconds with 13 queries
