Results 1 to 6 of 6
Thread: Miller 302 - 120/240 work -- NO weld power
    Wondering if it's worth fixing or is this going to be a board swap $$$
    Don't have the machine here yet but will in a week or so.
    All I know so far is it has power on the genset side but none for the welder side???
  2. Likes 12V71 liked this post
  3. #2
    Re: Miller 302 - 120/240 work -- NO weld power
    Never had one of mine do that. I can check the schematic I have tomorrow. But it does sound like a problem with the weld generator. Remember, they have separate generators for weld and power.
  5. #3
    Yes, I believe it's very similar to my 325 just lower ratings??? I should have it here sometime next week to work on. Also have a 250 coming in and a 225nt that just shuts down when you try to strike... at least that's what I been told
    Now I have to find time to troubleshoot these.... I *might* have to stay away from the pol thread more
  6. Likes 12V71 liked this post
  7. #4
    IF it turns out to be a board problem, the main control board is a triple layered type with circuit traces sandwiched in between the layers. This makes this board "non-repairable" by most repair shops. I have had one repaired by a local former satellite technician years ago and it did take him two tries to nail it.
    Save Second Base!
  8. Likes 12V71, ronsii liked this post
  9. #5
    IIRC, the 302 weld output is direct to the studs, It may have an excitation issue, board etc. Also I remember a 5 amp fuse just behind the engine on the left side looking from the control end that powers up the board and excitation.
    The 325 is a whole different animal, if I'm thinking right it has a single generator with dual output windings in the stator. and then goes through a board for the weld at idle feature.
    Duane got there while I was hunting and pecking.
  11. #6
    Uggghh, yeah I hate working on multilayer boards... some can be a real pain to get components off without killing the thruhole
    @12v , thanks for the info I don't know why I was thinking the 302 was same as 325... thought I read it somewhere??? oh well... should be an adventure
Page generated in 1,611,250,784.12437 seconds with 14 queries
