Results 1 to 5 of 5
Thread: 450 sq ft welding fabric NOS $150/roll Maryland Area
    Aug 2020
    I have 2 rolls of 84 CH fabric still in cellophane.
    Each roll weighs 65 lbs and is 150x3 ft.
    Prefer local sale but will ship at buyer expense.
    AVSIL® 84CH® WELDING GRADE SILICA FABRIC
    Product Description
    AVSil® 84CH® Welding Grade Silica Fabric is a lightweight high silica content (≥96%) fabric that is
    engineered to withstand welding sparks and light molten metal splatter while protecting personnel and
    equipment. The superior strength, weave construction, and high melt point 3000°F (1649°C) of AVSil® 84CH®
    Welding Grade Silica Fabric makes this fabric ideal for light welding and spark protection during hot work
    operations. AVSil® 84CH® Welding Grade Silica Fabric can be used for fabricating all types of welding
    curtains, blankets, or pads. Fabric properties will be maintained at intermittent temperatures up to 1800°F
    (982°C). AVSil® Silica Fabrics are used extensively in the Power Generation (Nuclear Approved), Refinery,
    Shipbuilding, Ship Repair and Metal Processing Industries.
    Features
    • Fireproof
    • Resists penetration of weld “slag”
    and passes welding “burn through” test
    • Excellent retained strength at temperatures up
    to 1800°F (982°C)
    • Easily sewn and fabricated
    Benefits
    • Protects equipment and personnel in the
    toughest welding applications
    • Protects against hot work fires
    • Wide product variety (blankets, curtains, mats)
    Technical Data Properties AVSil® 84CH® Welding Grade
    Silicon Dioxide Content ≥96%
    Nominal Weight: oz/yd² (g/m²) 18 (610)
    Nominal Thickness: inches (mm) 0.030 (0.76)
    Width: inches (cm) 36 (91.4)
    Weave Construction 8 Harness Satin
    Melt Point: °F (°C) 3000°F (1649°C)
    Sep 2005
    Cave Creek AZ
    Re: 450 sq ft welding fabric NOS $150/roll Maryland Area
    Got a pic?
    Apr 2014
    MN/WI
    Lincoln Idealarc TIG-300
    Aug 2020
Size:  89.3 KB Off white color
    Aug 2020
    i can get a picture of the roll later if you're interested.
Page generated in 1,604,066,195.73055 seconds with 12 queries
