Page 1 of 3 123 LastLast
Results 1 to 25 of 71
Thread: Help with rusting stainless posts
    Ct
    So perhaps this is because I used 304 stainless, perhaps it's the way I drilled the holes, perhaps it's the finish on the stainless, anyway, I'm in trouble and I need to figure out how to fix this pretty fast,
    I clear coated the posts after fabrication, I thought that would help.
    I would prefer to not have to replace everything here and lose a bunch of money.,
    Any ideas? Could I clean it well and coat with a 2k clear?
    Clear powder coat?
    If I used 316 would it have made a difference?
    I've seen other cable rails that are rusted out as well after years, the problem with mine is that it's only been a few months,
    Ct
    Re: Help with rusting stainless posts
    This is not something I can replace a few posts at a time to help spread the cost out, I'd have to do everything at once and spend a few thousand dollars
    Sent from my moto g power using Tapatalk
    I would guess the issue is the sharp edges, cable vibration and the salty environment. I am just speculating. Based on location of rust and even the corner on the tube. Perhaps clean and add insulators?
    The only exterior cable rail, the cables showed rust spots in short order. I suspect shop dust. Since it was so rapid.
    Brett, from Down Under was on here recently. He does a lot of cable rail. Perhaps he will offer some assistance.
    Fredericksburg, VA
    Have you tried some oxalic acid to remove the oxidation?
    When I made a sculpture with a mix of mild and stainless, I had some rusting spots on the stainless. I applied some of that acid on the spots and it removed them. The stainless did not rust again. I do not remember what grade of stainless I used.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
    Ct
    I'm sure that has something to do with it, I can try to get some plastic insulators,
    Ct
    I saw on a cable rail website, they sell stainless cleaner to remove oxidation, I could try that, they also sold something they claimed passivated the stainless, which I'm sure would help if it worked.
    Any opinions on the 2k clear coat?
    I guess if it was an issue with the sharp edges, the clear wouldn't solve that.
    Sep 2015
    SE Pa
    This what happened to my stainless pipe and plate after I hit it with a carbon steel wire brush . If using a grinding wheel it has to be new with no contamination.
    Is the cable stainless or galvanized? If galvanized this may be where rust is coming from
    Ct
    Quote Originally Posted by Bls repair View Post
    The cable is 316
    Fredericksburg, VA
    I have used rattle can Rustoleum on a few of my stainless items but not 2K.
    The rattle can will drip or run in a heartbeat if you are not careful.
    I used it mostly to lessen the fingerprints and am not sure if it would help your situation.
    Edit: I would wager the cleaner you see is similar to the oxalic
    Millermatic 252 MIG
    Fredericksburg, VA
    Phil,
    Shoot me a PM with your address and I will send a snack bag or ziploc bag of the stuff you can try for free.
    I bought a 5 pound bag and have only used a few ounces.
    Millermatic 252 MIG
  11. Likes scsmith42, N2 Welding liked this post
  12. #11
    Aug 2016
    Iowa
    I have used Citrisurf products before with great success, look under the "rust removal" tab.
    http://citrisurf.com/
    RideKTM350
  13. #12
    Los Angeles
    http://www.sperkoengineering.com/html/Rust.pdf
    from 2014 but there are some suppliers listed for Rust removal on stainless.
    MM211 (Sold)
    Klutch 120v Plasma cutter
  14. #13
    NW New Jersey
    https://www.mcmaster.com/passivating-gel
    For about $28 Mcmaster will have it for tomorrow. Probably available on amazon somewhere.
    The gel works well on vertical surfaces, even in the sun. I often use the white scotch brite pads with this because it wont affect the finish much where you clean. Using grey or red scotchbrite is good for polishing(rough).
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  15. #14
    Nov 2014
    Southern CT
    What did you use for clearcoat? You probably will have to remove the clear to get to the rust.
    Ernie F.
  16. Likes rlitman liked this post
  17. #15
    Ct
    Rustoleum, yeah I'll probably have to do that
  18. #16
    Stuff they use for removing rust on chrome like vehicle bumpers might work too. Any auto parts store should carry it.
  19. #17
    Mar 2005
    Under a Rock
    Yeah I would go with insulators after neutralizing the rust.... but it still looks like a bunch of labor... prolly have to disassemble the whole thing to drill bigger holes for insulators...
    might be easier to clean the rust, repaint and use plastic coated cable...... WITH insulators to boot!
    salt water is kickin yer azz.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  20. #18
    Is heat or disturbance from drilling enough to cause the need to passivate?
  21. #19
    Feb 2016
    Myrtle Beach
    I don't have a lot of experience with cable rail. But work on ocean front amusement rides and boats. In my experience 304 stainless doesn't last a season before showing some rust which is why we use 316 for anything stainless close to the ocean. I do hope you figure out a way to deal with it without replacing it though.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    HTP Invertig 221
  22. #20
    Sep 2016
    What kind of drill bit did you use ?
    From my experience working in the field , we typically use cobalt end mill drill bits for stainless and cobalt bits . Regular drill bits introduce carbon to the stainless sort of like using a carbon brush on stainless . Itll make it rust .
  23. Likes snoeproe liked this post
  24. #21
    Feb 2016
    Six Mile SC
    Quote Originally Posted by l0w n slow View Post
    That's what I'm thinking. The rust you see is drill bit contamination. Once you clean it off real good, it won't come back.....Hopefully.
    CG
  25. #22
    I would expect rust around the bolts it were from a drill bit. Also if it has an intact clear finish, then there should be no rust. Many years ago it was not unusual to find a baluster fully deteriorated underneath powder coating. Always caused by porosity at a higher location.
    I suspect the coating got compromised and salty mist is leaching, given the spread out pattern caused by dripping and capillary action. Still just speculating?
  26. #23
    Jan 2011
    W. Wisc
    I recall you asked about 304 vs 316 a while back. 316 is the one for Oceanside applications, outdoors. But either way you need to passivate after fab and welding. Find a metal finisher that can do it (or electropolishing if you want it shiny). Build that into your price in the future. If you remove the posts and get them passivated it should greatly help, but you are still stuck with 304 where it should be 316. You will probably have to eat the cost this time, but should plan for it.
  27. #24
    Wonder if something like this could work.
    https://www.walter.com/products/weld...ox/surfox-mini
  28. #25
    Ct
    Phil,
    Pm sent
Page generated in 1,713,243,670.76290 seconds with 19 queries
