Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
Thread: Need advice for MIG welding 22GA steel flashings
    Southern California
    Re: Need advice for MIG welding 22GA steel flashings
    You usually use a large, flame heated soldering iron. Looks like a metal wedge with a handle, and a torch pointed at it. Acid flux and plenty of lead. I hear it's hard to keep the galvanized coating from getting damaged in the process.
    The downside is I've seen the solder eaten clean off in about 10 years in severe situations due to galvanic corrosion. Layering is really the way to go, but a good sealant would likely outlast even soldering these days.
    Apr 2019
    Denver, CO
    Lol, as I said, I've paid people to make it in the past but if you skip the first two minutes of this video, it gets to the point. There may be better videos but this is the first that came up. I have done some small flashing modifications with a propane torch it doesn't take very much heat.
    The solder melting point should be less than 400 F so it's much less than OA. Just to be clear, we're not talking about high-temp silver solder that is at near brazing temperature.
    May 2016
    Cottonwood, AZ
    That is very interesting. I have never seen that before. Ok, now I see. I would not have imagined that.
    Hobart Handler 190
    Hypertherm Powermax 45XP
    Lincoln Ranger 305G EFI
    May 2016
    Cottonwood, AZ
    I wonder how much different it would be to do an outside corner joint?
    Hobart Handler 190
  5. #30
    Laredo + Midland/Odessa
    Quote Originally Posted by Keith Merrell View Post
    Probably a lot less heat needed.
  6. #31
    Looks great
    I would have used at less 18 ga stays flatter after welding
    Hello all,
    I have been asked by a customer to make some metal flashings for a roofing system. They are made of 22 GA steel. I tacked them together with MIG. How would you recommend I weld them out while keeping warpage to a minimum?Attachment 1714591Attachment 1714592Attachment 1714593
  7. #32
    Apr 2019
    Denver, CO
    Any chance you could partner with the roofers at this point? Assuming they have the soldering equipment to finish it out?
  8. #33
    Dec 2023
    Thanks for the information!
  9. #34
    Brethren, Mi
    See how it works with mig. But I bite the bullet if I can and use material a ga heavier even if I have to suck the difference in cost if it doesnt bother somebody or even upsell that feature. Would be 2x as easy 20 ga and another notch at 18.
  10. #35
    Brethren, Mi
    I have seen some expensive good lookin stuff soldered together that come apart with joint not particuarly well designed. Welded sheet metal is really strong, it rusts but its tough.
  11. #36
    Dec 2023
    Quote Originally Posted by aidnnsma View Post
    I recently stumbled upon a fantastic resource that might assist you in your MIG welding journey. If you're dealing with 22GA steel flashings, precision is key, right? Read more about it here. The article provides valuable insights and tips to ensure a seamless welding process. When working with thin materials like 22GA steel, patience and technique play pivotal roles. Share your experiences and let's build a knowledge hub for aspiring welders. Avoiding emojis to keep the discussion focused. Happy welding!
    forgott to add, the information was helpful
  12. #37
    Solder is no good for that design. You must have overlapping seams for soldering. You don't solder butt welded steel sheet metal.
Page generated in 1,713,251,996.81004 seconds with 17 queries
