Results 1 to 13 of 13
Thread: 1-1/4" Steel Rod cut w/ Evolution Rage2 Steel Blade - use cutting fluid?
    May 2016
    California
    I would like to cut some tubing end caps from a 1-1/4 inch steel rod with an Evolution chop saw - this may put the machine to its limits, is this safe? Should I use cutting fluid?
    The tools and material specifically:
    Evolution 15-Amp 14-in Corded Chop Saw [1,450 RPM at no load]
    Evolution Power Tools 14BLADEST Steel Cutting Saw Blade, 14-Inch x 66-Tooth
    Low-Carbon Steel Rod, 1-1/4" Diameter, 1 Foot Long
    TAP Magic Protap cutting fluid
    The Evolution saw website specs state a Mild Steel Plate - Max. Thickness: 1/4" -- and this rod would be 1 and 1/4 inch, so much larger that the quarter inch max.
    Just go slow and steady, should be OK? I wonder how long the cut will take, likely multiple pauses for the blade to cool, etc.
    Aug 2018
    'ta town, KS
    Re: 1-1/4" Steel Rod cut w/ Evolution Rage2 Steel Blade - use cutting fluid?
    I would not have even read the maximum in the manual. I would have just cut... slow and steady like you wrote.
    Mac
  3. Likes jonnymacuser liked this post
    Fredericksburg, VA
    I cut several pieces of 2" solid square bar the other day using my DeWalt 14" dry cut.
    I think I had a stadard DeWalt blade on it. I can't remember the number of teeth.
    Slow and steady pressure and about a minute later it was done.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  5. Likes jonnymacuser liked this post
  6. #4
    Sep 2016
    Detroit, Michigan
    I have the Evo 380CPS and have cut many, many pieces of 1" solid square, 1" solid round, 1.25" solid round and 1 x 3" solid bar along with other stuff...no problem at all. The more you cut thick stuff the shorter the blade life will be, but it's not going to cause damage.
    http://mivise.com
    Millermatic 252 W/Spoolmatic 30A
    Miller Dialarc 250
    Hobart Champion Elite
    Everlast PowerTig 210EXT
  7. #5
    I suggest buying a used Milwaukee portaband. You could probably buy one for what that blade cost.
    I've seen many for $50 to $100
    A portaband is an awesome tool to have.
  8. Likes jonnymacuser liked this post
  9. #6
    Sep 2008
    Dalton, GA
    I have the 7 1/4” Evolution and a Harbor Freight ($99) portaband. If that’s the choices, I would quickly go with the HF portaband.
    In reality I would use my old Kalamazoo band saw as first choice.
    Burt
    _____________________
    Millermatic 211
    Miller 375 Plasma Cutter
    Miller Thunderbolt XL AC/DC - sold
    Hobart Handler 120
    10FtDrillBit.com
    MyWelds.com
  10. #7
    Laredo, Tx
    Cutting fluid would make a mess. Stick wax lubricant will be better IMO. Less mess I guess you could say.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  11. Likes Oldendum, jonnymacuser liked this post
  12. #8
    May 2016
    California
    Wasn't too bad ... didn't get to much over 100dB.
    Name:  Screen Shot 2020-08-21 at 4.21.25 PM.png
    Name:  Screen Shot 2020-08-21 at 4.20.53 PM.png
  13. #9
    Laredo, Tx
    decibel level is relative to distance. If you got 100 dB @ 6ft, you'd get about 104-106 dB @ 3ft.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  14. Likes jonnymacuser liked this post
  15. #10
    May 2016
    California
    I wear over the ear ear-muffs for protection. I feel bad for my neighbors.
  16. #11
    Los Angeles
    I love my HF Portland- can cut and still hear the radio
    MM211 (Sold)
    Miller 125c Plasma 120v
  17. #12
    I've attempted cutting larger diameter round stock with a cutoff saw (aka chop saw, not a tooth saw), and it was a disaster. I only cut the bigger stuff with the bandsaw nowadays.
    I know this doesn't relate to a cold saw, especially a small cold saw, but it's germane I think. Circular saws build heat, and they have to fight a lot of load as they cut. A bandsaw has the same load from beginning to end on a thick cut (well, sorta). Either way, a bandsaw excels on thick stuff.
  18. #13
    Aw Hell, I didn't read the thread good...........was only 1.25OD round stock. That's child's play with almost any kinda saw. I was talking about 2"+ round stock.
  19. Likes jonnymacuser liked this post
Page generated in 1,603,511,976.80495 seconds with 13 queries
