Results 1 to 4 of 4
Thread: sa 200 green light oil pressure switch
    Nov 2012
    ROCKVILLE ,,VA
    Me got 1973 planning to sell to friend got running rebuilt mag, carb, set governor 115 on rec then working on other side alternator seem not charging on gauge or oil pressure green light does not light up, so went checking oil pressure switch hook test light on wire connection light came on with engine off? Me thinking that it supposed to be on with engine running? Okay went ahead with test light on started the engine and light went off with engine running? Disconnected wires started engine again it will not idle down with wires unhook? Know idler board need 12 volts , so any ideas thinking oil pressure switch normal off when engine running?
    Oct 2013
    cntrl FL
    Re: sa 200 green light oil pressure switch
    Sounds like you have the wrong oil pressure switch. The switch should have continuity "ONLY" when the engine is running. Go to Stumps, BWparts, Welderparts warehouse, Bills welding repair, They will have the correct oil pressure switch for this application.
    SA 200s : 1944 1945 1963 1965 1969 1980
    1981 SA 250 D3.152 DC only
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart GPB 258 Pipeliner
    Hobart GPB 261 Mainliner
    Hobart Airforce 250
    Everlast PA 200st
    Nov 2012
    ROCKVILLE ,,VA
    Byw200 feel kind stupid when putting my test light on oil pressure switch me was hooking alligator clips on both terminal basically by passing the switch !! Replace switch with new one it leaking oil guessing oil light on dash is bad? ,,got another problem engine runs real good but has ticking noise in valve area? Adjusted the valves didn"t change ,, thinking wrist pins ?,lifter noise ? Seem to be near # 1 cylinder
    Oct 2013
    cntrl FL
    Yes, I've done some silly things myself trying figure out what was happening on certain things. When adjusting the valves, I just rotate the engine and watch the valves as they close and then turn a tad more so I know that the tappet is on the heel of the cam lobe, and had never had a problem. Although, if the valve lash is correct, then there is something else going on of course.
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart Airforce 250
    Everlast PA 200st
Page generated in 1,603,800,994.01511 seconds with 11 queries
