Results 1 to 4 of 4
Thread: 89' Sa250 alternator melting wires
    Feb 2016
    Texas
    Picked up a machine the other day had no problems. Welding fine power to outlets. Get home from a job and noticed wires coming from oil pressure sender looked melted. Followed the wires(melted) around to the ammeter gauge and to the splice with the alternator wire(melted) to the idle control switch(not melted). I'm not sure what's going on here. Is my alternator bad? The wires are burning shortly after start up. Also is a diesel machine with Perkins 3 cyl. D3 152 model
    Aug 2020
    Re: 89' Sa250 alternator melting wires
    I am no expert but maybe the voltage regulator in the alternator has gone bad and the alternator is putting out more voltage than it should normally do. One check is to start the machine and probe the battery terminals to see what voltage the alternator is sending to it. Good luck, I hope you get the issue sorted out.
    Feb 2016
    Texas
    After cleaning all grounds and replacing the melted wires everything seems to be fine. I believe the original wire was corroded inside the insulation. Good luck if anyone else runs into the same problem. Thanks Rugrat for taking the time to help.
    Aug 2020
    I am glad to hear that you got the issue corrected!
Page generated in 1,603,830,412.24341 seconds with 11 queries
