Page 1 of 3 123 LastLast
Results 1 to 25 of 71
Thread: Farmersammm's Tire Repair
    Gotta bit of a problem
    Name:  tire repair1.JPG
    No problemName:  tkqe4fh-smiley-two-thumbs-up175028_285604.gif
    Name:  tire repair2.JPG
    Name:  tire repair3.JPG
    If it makes it through the day, I'll be 100% dipped in gooooook
  2. Likes AlabamaJoe liked this post
  3. #2
    Jan 2016
    northeast USA
    Re: Farmersammm's Tire Repair
    time for newer tires, those are dry rotted beyond repair..unless you want to foam fill them, but if you had them loaded you wont get the weight back...that patch wont do squat, maybe if it was on the inside it would make a small difference..if they are tubed, let the air out and use some paracord and stitch the crack closed, then put the patch on the inside..
  5. #3
    Oct 2012
    Sacramento, California
    And you're worried about people not wearing masks.... Yeeeesh.
  6. Likes ronsii, thegary, bubmiller liked this post
  7. #4
    Jan 2016
    northeast USA
    Quote Originally Posted by rugrat View Post
    I was wondering if he made the repair while wearing a mask. Just saying.
    looks like he used his mask for the repair....
  8. #5
    I wouldn't waste foam on those, once the rip starts the foam crumbles out through the hole. Had a JD 644 loader with foam fill tires and learned that when the cords wore through. Used a garden hose and a chainsaw to cut around the tread of the rest of the tires and drove it around in circles until all the foam fill fell out and got 4 new radials put on it. Then had to add 1,000 lbs of counterweights to make up for the loss of weight of the foam.
  9. Likes Hobbytime, ronsii liked this post
  10. #6
    The old they sold a "boot" that fit inside the tires. It was specific to tire size. Usually installed in tires that were in good shape.
    A tube was installed even if tire was tubeless.
    Sam definitely got his money's worth.
  11. #7
    You missed the point. farmersamms tires are worthless and worn the heck out!
    I didn't miss the point. I stated a boot was used for tires in good shape.
    This was to inform those of you that know nothing about farming.
    Farmers get the last thread out of tires. They'll spend hours trying to make something work instead of spending a $100.00.
    I'm not referring to those with millions of $$ in equipment. One million today will cover one combine and tractor. Then you need 500 or 600 gallons of Diesel to fill them.
    It's the little guys like Sam and many others out there.
  12. Likes bubmiller, N2 Welding liked this post
  13. #8
    Yep, you definitly missed the point. First off, his tires are beyond repair or in good shape for repair. Myself having been raised on a farm and making ends meet means to me that you actually dont have a clue about what farming is. Stick to your so called welding and leave the farming skills to those that know what they are talking about by their own experience! How many acres of rice or soybeans did you farm? How many acres of wheat and rye grass did you farm? Take your BS lies elsewhere and stick to welding! Carry on!
    Being raised on farm?? Wow, you must not have paid attention.
    Apparently public relations isn't your specialty.
    What BS lies ? I've been farming crops and livestock smart-*** and I do know my **** on farming and welding. I'm even a UNION proffessional and donate my time to help others.
    It's better to let people think you are stupid then to open mouth and remove all doubt.
    Just saying.
  14. Likes N2 Welding liked this post
  15. #9
    Jan 2016
    northeast USA
    once you foam fill you have to cut the tires off the rims..a friend had to put new tires on a towns big pay loader and the tires were foam filled, he tried to cut them off and then the rims were covered, he just told the town it would be cheaper to buy the new rims than to waste all the time cutting the tires and cleaning the foam off the old ones...
  16. #10
    You are not the only union professional here. But by your lanuage I can tell you are definitely not so professional! I am going to break protocol here of being a professional here and just say that I have a root that is dry and arid, so if you please, suck on it and provide moisture to it that it survives the drought!
    My condolences. There are help centers available.
    I know they are other professionals and members here that respect opinions from others .
    What lies did I post ? It's OK I consider the source .
  17. #11
    Mine had 25"(24"?) drop center rims, after cutting the center of the tread and driving it until the foam fell out, the rims looked like new, none of the foam stuck to the rims. Tire guy busted the old beads off and installed 4 new tubeless radials in 3 hours. It was quite the floppy rough ride on the sidewalls trying to bust out all the foam chunks.
  18. Likes Hobbytime liked this post
  19. #12
    Jul 2018
    Cumbria, UK
    The one sensible post on here was the one suggesting letting it down, pushing the tube back in, and stitching it up with paracord.
    relatively simple, and will get a few more years out of the tyre.. hopefully.
  20. Likes Hobbytime, Lis2323 liked this post
  21. #13
    Mar 2009
    Should be fine Sammmmmm
  22. #14
    Jan 2005
    Sammy ,
    you have finally made it big time! You seem to have passed the negative % of post replies that Chuckie Cheese gets.. Although he worked harder at being a dick..
    Off topic note to you.. Traded away another 60i Plasma cutter for a machine tool.. Remember the last one got me a Cincinnati Mill.. This one is quite different, and made in Taiwan like your mill.. Really high quality unit though..
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
  23. Likes ronsii liked this post
  24. #15
    Apr 2011
    minnesota
    Obviously anyone who thinks foam filling those tires hasn’t priced it. Probably be close to a thousand bucks a tire. I am sure sams fix was temporary to get by till a better solution can be had
    Millermatic 252
    millermatic 175
    miller 300 Thunderbolt
    lincoln ranger 250
    smith torches
    lots of bfh's
  25. #16
    Mount Tabor VT
    I have an old tractor doesn't see much use any more. 3 point hitch wood splitter hasn't been off it in a few years. Ten or twelve cords a year.
    I bought liners from Gemplers, got me through 5 years until I did a major tire swap involving 4 tractors. The old carcasses were the ones disposed of. Now it has tires tore up when some previous idiot didn't adjust the sway chains & raised the bush hog too high.
  26. #17
    Jan 2016
    northeast USA
    If sam foam fills those tires or does a patch on those tires, he is living on borrowed time and does not value his life that much! Tires are expensive but not as expensive as human life! He is free do what he wishes and it is on him. A failure on his part means that he will not be posting here in the future. His choice!
    I agree those tires are shot, but if hes working on flat land and NO hills, the tire will just go flat..no roll over or dangers..but where I am, if your coming down a steep hill with a load of hay and the tire deflates fast..you will have some safety issues...for sam it would be more of an inconvenience of a stuck tractor out in the field and a long walk back to get another truck and tools to remove the rim and tire to get fixed...
  27. Likes AlabamaJoe, ronsii liked this post
  28. #18
    Sep 2015
    SE Pa
    You could put this into the cracks Name:  7FF69E24-0CA6-46E4-84CF-AA7FF2A0A0B6.jpg
  29. Likes ronsii, bfjou812 liked this post
  30. #19
    Dec 2008
    Quote Originally Posted by Bls repair View Post
    Finally, the CORRECT answer!
    I bet farmersammmmmmmmmmm is laughing his *** off at most of these responses!
  31. Likes ronsii liked this post
  32. #20
    Aug 2012
    AR
    Samm is trying to fix a tractor tire, not build a boat out of a screen door!!! I'm thinking a 5 gal. bucket of epoxy, LOL
    Stay with us Samm, somehow we'll get your tires fixed.
  34. #21
    Nov 2008
    Bolt a patch in from the inside, with a thinmetal strap holding the tire together on the outside with a carriage bolt facing out, running through a thick rubber boot from the inside to the outside, nuts tightened, welded and studs sticking out trimmed. Seen many done that way.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
  35. Likes ronsii liked this post
  36. #22
    Nov 2008
    Just found a pic of what I am talking about.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
  37. Likes ronsii, walker liked this post
  38. #23
    Yep, seen a few done that way myself and then if you want to make it purdy shoot some black FlexSeal over it
  39. Likes lugweld liked this post
  40. #24
    Sep 2015
    SE Pa
    Lugweld ,who ever makes those clamps better put on a second shift for that tire
  41. Likes ronsii liked this post
  42. #25
    Dec 2016
    wait,this is mainly a welding forum right? why not weld the cracks shut?
Page generated in 1,713,239,847.50896 seconds with 19 queries
