Results 1 to 10 of 10
Thread: Hobart AirForce 500i Plasma No pilot arc
    Keaau, Hawaii, the Aloha State
    I am trying to troubleshoot my Plasma Cutter as there is no pilot arc anymore.
    Only LED light that is on the front panel is the power on. No other indicators lit.
    I get compressed air going out the torch, but no pilot arc.
    I checked for continuity between the inside of the machine to the torch handle, there are a total of 4 wires plus two large.
    - This space for rent. Inquire within.
    Re: Hobart AirForce 500i Plasma No pilot arc
    Have you gone through the manual and check the maintenance items and the troubleshooting section? sounds like a consumable issue...
    Thank you for a response. I figured it out but it required me to cut open the sheathing for the torch. I found a broken air line, it was totally cut into two pieces. Reconnected everything back up and the plasma works.
    Dec 2015
    Just curious, if you had a broken air line how were you getting air out the torch ?
    There was some air coming out of the torch head, but majority was getting out of the sheathing. I guess there was an arc that developed, but the concentrated air wasn’t blowing the arc out of the tip.
    I connected everything up (minus the sheathing since it got cut) and the plasma works as it should.
  6. Likes ronsii liked this post
  7. #6
    Wow!! for the air line to be split in two is strange... either it got too high of pressure at some time or could be the line is is just getting old and brittle which means you'll be having more line issues in the future.
    Glad you figured it out and it's working again!
  8. #7
    Not sure if I ran the line over with a hand truck or my welding cart.
    The rest of the line seems good, as I inspected the wiring and air line from the machine to the torch handle.
    I temporarily put everything back together and used the plasma cutter successfully the whole day today. Am waiting for my TIG torch cable cover from Amazon so I can have the plasma torch cable protected.
  10. #8
    Ceres, California
    please insulate real good where you cut into the torch lead cover.
    You don't want the voltage to get out and bite you. can be around 300vdc.
  11. Likes stanward liked this post
  12. #9
    I re-used the rubber sheathing that I cut, cable tied it every foot. Then used cheap corrugated flex loom to cover that and cable tied that every foot. Sparks still could get in and melt the plastic air line. I ordered a TIG torch cover from Amazon. It uses a zipper to enclose the torch cable.
    For now, I am being very cautious of where the sparks can fly near the torch cable.
  13. #10
    Quote Originally Posted by stanward View Post
    A lot of times on repairs like yours when I have to split the outer jacket I'll use a bunch of liquid tape on my way out to keep things waterproof.
  14. Likes stanward liked this post
Page generated in 1,603,590,434.69906 seconds with 13 queries
