Results 1 to 17 of 17
Thread: What method and process would you use for this?
    Sep 2014
    Austin, TX
    Iím interested in trying to do something like this. Curious what methods and process you would use to get a similar style.
    Iím thinking that it might be best with Tig, tacking welding rod to the sheet metal in a laid wire technique, and then with low power/pulse run over it Without much lateral movement?
    The color makes it hard to tell, but do you think itís a special rod? Brazing maybe?
    I have Mig, Tig, stick, and OA, so open to any ideas.
    Nov 2004
    Southern Montana
    Re: What method and process would you use for this?
    Of course I may be wrong... but, it sure looks likes solder to me... the way the intersections are blended together. You can test it to see how soft it is by scraping with a knife blade.
    Perhaps, brass material with pencil sketched pattern then headed between lines?
    I'd think some kind of solder. It looks similar to stained glass but without glass.
    The pencil or graphite outline will deter flow of the filler giving crisp lines.
    Jan 2016
    northeast USA
    looks like they made the grid out of copper wire then coated it with solder then chemically treated to change color..just a guess...
  7. Likes tapwelder liked this post
  8. #7
    I believe it is silicon bronze put on as cool as possible with tig while using the above mentioned technique to stop it from flowing too much. The look it has is after the bronze has tarnished.
  9. #8
    Well his materials list shows steel and bronze... just looking at the details I would actually guess he cast the bronze web separately then formed and tacked it in places as evidenced by the edges and a few center areas.
  10. Likes psacustomcreations, motolife313 liked this post
  11. #9
    Nov 2004
    Southern Montana
    You're, really, missing out, if you don't take time to go to Casey's site for a look. He is an amazing, talented artist.
  12. #10
    It wasn't even done on the backing. You can see only the ends and random tacks are attaching it to the backing.
    The entire pattern doesn't look attached like say where the ends stop almost like it was made elsewhere and laid on and all the end melted in with tig or oxy/acetylene. Almost a gap under some edges.
    Pattern was cut and melted on top to get that rounded effect and then laid it place and attached.
  13. #11
    It looks like Lost Wax Casting
    Using welding would be hard to do.
    Quote Originally Posted by whiskeymike View Post
  14. #12
    Sep 2014
    I’m interested in trying to do something like this. Curious what methods and process you would use to get a similar style.
    I’m thinking that it might be best with Tig, tacking welding rod to the sheet metal in a laid wire technique, and then with low power/pulse run over it Without much lateral movement?
    The color makes it hard to tell, but do you think it’s a special rod? Brazing maybe?
    If you wrapped the bottom thing with a thin piece of copper and took a tig torch and blew holes in the thin copper if that would give you that look?
    Sincerely,
    William McCormick
  15. #13
    Mar 2014
    I'm always amazed about WW. Here's a tip: you have the mans name and you have internet. A 30 sec google will give you the answer; did for me - applique.
  16. Likes psacustomcreations liked this post
  17. #14
    Sep 2014
    Austin, TX
    Quote Originally Posted by Yofish View Post
    Maybe that’s accurate. I assume the worst and I should probably be more optimistic. I’ve asked artists in the past and a few have acted like I asked for naked pics of their wife. I get It, it’s their livelihoods and they’ve put a lot of work into it.
  18. #15
    Mar 2015
    Milwaukee, WI
    Repoussť and chasing are more closely related to sculpting than welding, although good artists use many tools.
    https://en.wikipedia.org/wiki/Repouss%C3%A9_and_chasing
  19. #16
    I guess I am just not seeing the amazement . I have not done it but I have no doubt I could do it as I described in post #7 and some patience. To each their own I guess. I have no motivation to want to try and never really saw the attraction of useless art.
  20. Likes ronsii liked this post
  21. #17
    Nov 2014
    PDX PNW
    I’m going with post 8 on how it works.
Page generated in 1,603,695,955.97804 seconds with 13 queries
