Results 1 to 4 of 4
Thread: millermatic 130 xp will start an arc but not maintain it
    Jan 2019
    I got this millermatic 130 xp that will not maintain an arc. I can also hear the contactor every time I press the trigger on the gun. I have it set up with flux core.
    do you guys know of any typical problems with this machine.Name:  IMG_20200901_202345.jpg
Size:  123.6 KBName:  IMG_20200901_202253.jpg
Size:  80.4 KBName:  IMG_20200901_202333.jpg
    Oct 2019
    Australia
    Re: millermatic 130 xp will start an arc but not maintain it
    Has it been flooded?
    Los Angeles
    Not sure of the problem but you have the roll of wire mounted upside down.
    The wire should feed from the bottom so it goes straight into the feed tube.
    https://www.millerwelds.com/files/ow...O1316F_MIL.pdf
    MM211 (Sold)
    Miller 125c Plasma 120v
  4. Likes CAVEMANN liked this post
    Ceres, California
    Try cleaning the inside of the drive housing where the Miggun plugs in.
    Needs to be bright clean Aluminum or it will weld bad and the wire may melt by the drive rolls. I use a rod a cut a slot in and slide in a strip of sand paper. then spin with a drill. after buffing clean with electrical cleaner.
  6. Likes Broccoli1, CAVEMANN liked this post
Page generated in 1,603,959,639.03626 seconds with 13 queries
