Results 1 to 15 of 15
Thread: skill level
    Sep 2018
    skill level
    I'm a novice at o/a cutting. A friend wants this:
    https://s-media-cache-ak0.pinimg.com...59c483827e.jpg
    Pretty sure I'd need to pick up a plasma cutter, but would I need a cnc table or would the right shoe or guide be enough? If a table isn't needed what skill level are we talking about? Could I get a couple extra sheets and put in XX hours of practice or is this a hire out job? I typically pick stuff up fast and my hands are steady after the first coffee, but I have no experience with something like this.
    Fredericksburg, VA
    Re: skill level
    Two easier options are to just use a cut off wheel and/or a circular saw. Draw the line and cut.
    With a cut off wheel or zip disc it might take 30 minutes and a dozen discs.
    You can buy blades from Diablo that cut metal and go on a standard circular saw. I spoke to them at a trade show last year and the 7-1/4 blades you buy at Home Depot are made just for that reason.
    Both those options will be fast and have virtually no clean up.
    A torch in a new hand will require a lot of clean up.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  3. Likes N2 Welding, ronsii liked this post
    Sep 2018
    Re: skill level
    The steel demon blade? Got one of those a while back, I was impressed. Thanks for the advice, don't know why I didn't think of that.
  5. Likes psacustomcreations liked this post
  6. #4
    Fredericksburg, VA
    Re: skill level
    Yes. That is the blade I was talking about.
    I would be careful about doing a plunge cut, but maybe use the zip disc to make the first part and then finish with the saw.
    Since the saw is larger in diameter, it will make it easier to cut straight lines.
    Millermatic 252 MIG
  7. #5
    Apr 2008
    NW ON Canada
    Re: skill level
    Looks way too heavy for my liking.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
  8. #6
    Sep 2020
    Re: skill level
    I picked up a 7*1/4 Admiral saw blade for my circular saw at Harbor Freight ,have made about half a dozen cuts with it on 1 x 1*1/2 x 1/8 steel tubing ,and it cut it great, straight ,and square. I believe it was 14.99. I got about 10 more cuts for this project out of 2 x2 x 3/16 , no reason why it won't cut them the same .
  9. #7
    Re: skill level
    I'll go along with what PSA says get a box of zip discs and mark you cuts out good.
    Looks like they handmade the hinge from pipe or similar...
    Also they used corten steel for that nice rusty look... but I see they tried to even it out by sanding unevenly...
  10. Likes psacustomcreations liked this post
  11. #8
    Re: skill level
    What is the thickness of that plate ?? I would get price from supplier and have plate cut to size and how much for cutouts.
  12. #9
    Apr 2008
    NW ON Canada
    Re: skill level
    I donít know. It looks heavy to me.
    Jason
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
  13. #10
    Fredericksburg, VA
    Re: skill level
    Quote Originally Posted by snoeproe View Post
    So what do you think about this door?
    The OP is being asked to do a job and has asked for advice on how to do it.
    Millermatic 252 MIG
  14. #11
    Apr 2008
    NW ON Canada
    Re: skill level
    Yes.
    Itís going to take one heck of a vertical support to keep that door level and square. Notice the brick wall thatís holding it.
    Jason
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
  15. #12
    Apr 2008
    NW ON Canada
    skill level
    Before I put something like this at someoneís house Iíd be asking them some questions.
    Will a youth/child be able to use it? How about a senior?
    Lots of folks enjoy the patina/rusted look. Will this dirty your clothing/hands when you use the door?
    Jason
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
  16. #13
    Aug 2020
    Re: skill level
Size:  138.7 KBName:  IMG_20190626_104928.jpg
    I built a similar design fence for a customer probably about 15 years ago and then had to go out last summer and make some repairs so I took these pictures. I used 16 gauge sheets for the panels and fairly substantial posts when I built it first. Because the holes were large and square I just used my plasma cutter and then cleaned up the edges with a sanding disc. The narrow slots that you are looking for would be best done with either cutting discs or a steel saw blade but because the gate does not appear to be framed, I'm thinking you would need to use probably quarter inch thick steel in which case a 7-in grinder with a zip disc would be your best choice. It's hard to hang on to and keep straight but short of a laser or water jet I think it's the only way you're going to get that look.
  17. #14
    Oct 2012
    East Van BC
    Re: skill level
    Order the panels from a cnc shop. Waterjet or plasma. Thank me later.
    SqWave 200
    Millermatic 190
    Airco 200 AC
    Hypertherm PM45
    Boice-Crane Band Saw
    Victor O/A
  18. #15
    Re: skill level
    Avoid plasma on the thin sheet or you'll have other issues unless you can have them cut it underwater...
Page generated in 1,603,960,134.96443 seconds with 13 queries
