Results 1 to 8 of 8
Thread: How can I fix this bench?
    Sep 2020
    We have this old bench that is full of rust but 1 part has rusts that ate away the metal. I did buy a piece of aluminum rod (3/4") which is the perfect size for the replacement. I am now wondering how do I go about doing this? I am new to welding and currently own a MIG 130 amp unit. Any suggestion would be awesome!
    Re: How can I fix this bench?
    Well.... you won't be able to weld the aluminum to the steel bench frame as they are dissimilar metals.
    I would keep it simple and get a piece of steel tubing like whats already there.. looks like there are two welds on each end of the existing design... unfortunately they left the ends open so water could run in an rust things up... when you reweld you 'could' weld completely around the joint.... but the thickness of the existing vertical tubing may pose problems to a less experienced weldor by blowing through the metal!!
    So what I would recommend doing as the easiest fix for a less experienced weldor would be to cut the existing rusty steel out of there at the green line... thereby leaving a thicker 'weldfilled' area for you to weld up to.
  3. Likes !sledhead! liked this post
    Mar 2005
    Under a Rock
    Cut the old piece out and go buy an 8 foot section of similar material.
    Then practice spot welding.
    Until you feel comfortable.
    (if not you will surely blow through it)
    Also do what ronsii said
    Leave those existing welds for a little extra meat to zap onto.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Depending on OD of horizontal , schedule 40 standard black pipe maybe better for you then tube with a thinner wall.
    Once old is removed you could holesaw uprights so horizontal pipe will slide inside. Cut it long enough so it will fit inside each upright.
    This will make welding much easier and you don't have to worry about holding it to tack.
    Make sure it's square to uprights.
  6. Likes ronsii, weldaholic liked this post
  7. #5
    Yeah, I thought about the holesaw idea also as a way for him to use his aluminum tubing but I have seem some of the import benches and they are really really think tubing in the first place!! so didn't want to weaken the verticals...
  8. #6
    Sep 2020
    You could bevel that sch 40, and get it tight against the far side of that vertical, and will support the upright from giving. To me thats your best option. More or less like a gusset . Anyway thats how I am visualizing it. The upright can't collapse if its got that sch 40 to collapse first.
  9. #7
    Cut it out. Leave it out. Weld the top to the leg, if necessary.
  10. Likes John T liked this post
  11. #8
    Sep 2020
    Thank you all for your replies! Appreciate it very much!
Page generated in 1,603,152,790.93106 seconds with 13 queries
