Results 1 to 3 of 3
Thread: Repair Obsolete Dewalt D287 Deep cut Bandsaw
    Got the saw several years ago for about 90 bucks. It was in pristine condition and the price was right. I did not realize it was discontinued . worst the blade would not track properly. It was always nearly half off a wheel and often pop off. Called Dewalt they informed me no parts/discontinued... but I should bend the shaft.
    Finally I decided to look into it. Looks like the just stopped short of adding a tracking adjusting screw.
    The photo is if the tension lever assembly under the front/non drive wheel. The top nut is the assembly pivot. The smaller screw is the tension lever pivot. The open slot on the left is a resting on a molded boss attacked to the case.
    I solved the track issue by placing a flat washer between the boss and the assembly. It is visible in the photo. Not sure how to make it permanent. Though no issues with it falling out.
    So, 5 years later...nailed it.
  2. Likes ronsii liked this post
  3. #2
    Re: Repair Obsolete Dewalt D287 Deep cut Bandsaw
    5 years ain't bad... I got things I should have fixed 25 plus years ago... I'll get to em' sooner or later
    Jan 2016
    northeast USA
    a little dab of silicone caulking will hold the washer and have some give to it in case it needs to move a little...
  5. Likes tapwelder liked this post
Page generated in 1,604,010,813.42499 seconds with 13 queries
