Results 1 to 25 of 28
Thread: 3" hole Mild Steel 3/8" thick
    Mar 2007
    MidWest
    Friend of mine ask me if I could make a hole in a cast steel column sq and 3/8" thick. I immediately thought of my torch. But he would like to have a clean 3" hole and I do not believe i can do that with oxyacetylene. Would a hole saw and going slow work? He would like a clean cut. Thanks
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Ranger 8 Kohler 20HP
    Victor/Harris O/A
    K 487 Spool Gun
    Colorado Springs
    Re: 3" hole Mild Steel 3/8" thick
    A slow hole saw and cutting fluid should get you there. Should be able to get it done in 30 min's max.
    Sent from my XT1635-01 using Tapatalk
    Lincoln 175
    Monkey Wards 230v. Stick
    Dec 2015
    Should work. Take a scrap piece of 3/8 and try it. You'll find out if the result is to his liking.
    A really good bi-metal hole saw will make quick work of that job. I usually cut thick stuff dry with an air jet keeping the kerf clear, cutting oil just gums up the chips and binds things up. Oh, pre drill the pilot hole, you bend fewer pilot bits when it doesn't have to drill through and catch the cutter when it breaks through.
    Before everybody screams about the dry cutting, get a Lenox cutter with highspeed teeth, I have some that have cut hundreds of holes and still cut well. Even up to 5" through 3/4" plate. Air and safety glasses are the key.
  5. Likes ronsii, Lis2323, Capt B liked this post
  6. #5
    Apr 2010
    geezer
    Quote Originally Posted by geezer View Post
    . . . if I could make a hole in a cast steel column sq and 3/8" thick -
    . . . thought of my torch . . . he would like to have a clean 3" hole
    and I do not believe i can do that with oxyacetylene . . .
    Would a hole saw and going slow work? . . . clean cut . . .
    What is a 'cast' steel column ?
    Until the introduction of carbide/tipped cutters - I considered hole-saws
    garbage technique for structural applications . . . and still do . . .
    Do you have the power [coolant/lube] to turn 3 inches without burn ?
    You left out 'the last part first' - what 'final operation' drives the hole be
    'clean' and requires tight tolerances . . .
    I have torch-cut holes to be tapped - cutting a 3" close tolerance hole is
    easy with an OA Circle-Burner . . .
    The downside: you have to have Old School skill - with said skills, it can
    be done manually - without a Circle-Burner . . .
    What is going in the hole . . . ?
    hth
    Opus
  7. #6
    They make a torch circle
    attachment for cutting torch.
    I works very good. I just drill 3/16” hole for the attachment and cut the hole.
    Later I used a magnetic pattern torch.
    The best was electric eye pattern torch
    Today they have cnc pattern torch's
  8. #7
    Here are the choices I would suggest:
    Either carbide tipped hole saw (first choice) or
    plasma cutter with a template.
    Circle cutting guide will be awkward for a small diameter such as 3”.
  9. Likes 12V71, ronsii, VaughnT liked this post
  10. #8
    I do the same with air even with annular cutters.
  11. Likes 12V71, ronsii liked this post
  12. #9
    I thought for sure you were going to post up a pic with a couple cold air guns working with the magdrill!!!!
    https://www.vortextube.co.uk/cold-air-guns
  13. #10
    That’s out of the budget for my farm /retirement/hobby shop
  14. Likes 12V71, ronsii liked this post
  15. #11
    LOL!!! I remember when I first saw the cold air guns show up in the catalogs!!! I really wanted one but they were pretty expensive... never did get one... now I see they're a lot cheaper!!! must be the patent ran out or something????
    P.s. I think you're taking this whole retirement/downsize thing too far
  16. Likes DavidR8, Capt B liked this post
  17. #12
    Mar 2007
    MidWest
    Thanks for all the replies, much appreciated. Obviously many of you have experience using hole saws in metal, I just never had a reason.
    Apologize for not listing why a 3inch clean hole. It is more appearance than function.
    So if I have it correctly, purchase a good quality by metal hole saw, hold the rpms down and drill slow and steady, pre drill pilot hole. No air jet so lubricate well and clean hole frequently.
    We will run a test piece.
    thanks for taking the time to reply
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Victor/Harris O/A
    K 487 Spool Gun
  18. #13
    Mar 2007
    MidWest
    [QUOTE=Lis2323;8767361]Here are the choices I would suggest:
    Thank you very much, I have seen many test pieces you post with your replies. Very thoughtful.
    What type hole saw is that please?????
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Victor/Harris O/A
    K 487 Spool Gun
  19. #14
    Not necessarily from this seller, but I bought mine off eBay.
    https://www.ebay.ca/itm/174130409771
    Edit. Just noticed this set doesn’t have a 3” (75mm) cutter)
    You will need to search for the individual one(s) you require.
  20. #15
    A lennox hole saw will cut thru that no problem. As mentioned predrill your center hole. I use cutting oil and lots of it. Probably more for coolant than anything.
  21. #16
    A photo would help and what the hole is used.
    A 3" hole is not hard to do.
    But it is cost if just welding or electrical maybe something else.
    I have used torch for welding to milling machine for ball bearings but I had look at cost.
  22. #17
    Jan 2011
    W. Wisc
    Vortex cooling has been used for decades. I recall it was used in tanks in WW2 to cool the crew some, so no way there are patents on it anymore. They are quite loud and use a ton of compressed air...
    -Dave
  23. Likes ronsii liked this post
  24. #18
    Yeah they do use a bit of air but I was meaning the miniaturized versions that came out in the 90's - more efficiency, less air... albeit less cooling btu's also not too bad on loudness especially when you have other machines running anyways.
  25. #19
    A circle cutting guide will do a 3" inch hole. A really clean tip is essential and the cut could be cleaned up with a flap disc in a die grinder or hand drill. Cut hole slightly smaller to allow for polishing it. Not too hard to make a simple circle guide. Kind of crude but makes a nice hole in thicker plate.
  26. #20
    Bilbao, Spain
    I think it hasn't been mentioned yet but it is recommended to drill one or two holes (say 10mm holes) on the inside of the circumference (just touching the hole saw cut line) to chips to evacuate so the teeth can keep on cutting. Otherwise you will clog the teeth and just creat heat. It prevents you from having to stop, blow chips, drill again, etc.
    If the hole is in the flat, it is pretty much mandatory. For the vertical, maybe not so much.
    Post a few pictures of the results of the operation!
    Mikel
  27. Likes ronsii, geezer liked this post
  28. #21
    Mar 2007
    MidWest
    Quote Originally Posted by Mikel_24 View Post
    Mikel
    Another good tip, thank you.
    It will be a day or two until a finished post since this project is at club house by the lake.
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Victor/Harris O/A
    K 487 Spool Gun
  29. #22
    Mar 2007
    MidWest
    3" TUNGSTEN CARBIDE TIPPED HOLE CUTTER
    BM-THC300_1
    0.0 star rating
    Write a review
    $109.99
    Dont think my friend will spring for this, we will try carbide tip conventional hole saw first. This is a one time project, if we had a series of these then a more substantial cutter would be justified.
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Victor/Harris O/A
    K 487 Spool Gun
  30. #23
    Feb 2019
    Snyder TX
    I worked for an old blacksmith back in the 70's. He used water & dish soap as coolant for drilling. Works pretty good & is easier to clean up afterwards than cutting oil, just blow it off & coat with wd40.
    Just don't let the bit get hot before you start cooling it. Hot bit/saw + water = cold quench.
  31. Likes Lis2323 liked this post
  32. #24
    Apr 2011
    minnesota
    I just use a regular bi metal hole saw in the drill press. I usually use air nozzle to help cool and remove chips. Go slow and wear earplugs
    Millermatic 252
    millermatic 175
    miller 300 Thunderbolt
    lincoln ranger 250
    smith torches
    lots of bfh's
  33. Likes ronsii, 12V71, Lis2323 liked this post
  34. #25
    for one, Torch and template.
  35. Likes Lis2323 liked this post
Page generated in 1,603,801,889.02440 seconds with 13 queries
