Results 1 to 11 of 11
Thread: Miller Pipe Pro 304 - How to keep the varmints out?
    Apr 2014
    West Virginia, USA
    I recently bought a Miller Pipe Pro 304. Mostly what caught my eye was the 12k watt generator. Having a welder combined would be nice too. It has about 2700 hours on it.
    I opened it up and the mice had been living in the inverter. Not surprisingly the welder doesn't work. I got it pretty well cleaned up. The generator seems to work fine. There are two boards inside the inverter (voltage regulator and power board) that control much of the generator function so I guess these work ok since the generator seems to do it's thing fine. I changed all the fluids and filters and have been using it for about 2 weeks. I think I will remove the inverter assy for a good cleaning in the future. I plan to work on getting the welder working but that will be over time. I found a Technical manual for this welder on ebay and this has a lot of detailed info so it will be an interesting project.
    The weather proofing is not so good and it has lots of holes in it for mice to enter, spiders, etc. I'm considering building a skid to set it on, getting it up off the ground will be a help and maybe closing up the fork lift pockets and any other big holes- maybe screw on covers. Also, it seems like it is not too rain resistant.
    I suppose all the Miller engine driven welders share much of these issues. Anybody got any suggestions on improvements? Maybe a rain hood made from 16 ga or so to go over the whole thing?
    Re: Miller Pipe Pro 304 - How to keep the varmints out?
    Saw a video of a person partially fill 5 gallon buckets with concrete set jack stands inside the buckets. Then set his vintage car on the jack stands. Vehicle was suspended a few inches off the ground. Rodents cannot climb the buckets.
    Apr 2014
    West Virginia, USA
    Now there's one! I sort-of live in the woods and it's a never ending battle with them. I put poison around to try to reduce the numbers but it's still a battle. Then there are also the little mud bees that fill up every hole in every exposed outlet with mud. I have to put electrical tape over any exposed outlet. Then there are the spiders. And on it goes.
    Cumbria, UK
    We started using those ultrasonic rodent scare things around our farm.
    Feb 2019
    Snyder TX
    There is a product called Fresh Cab that we use in tractors & equipment to keep them out. Works pretty good & will last a couple of months. works in any enclosed space. Most implement dealers carry it in stock or it can be ordered from Amazon.
    https://www.amazon.com/Fresh-Cab-Bot.../dp/B00L236OMW
    I installed a bunch of those if different areas quite a few years ago... still saw evidence of the little buggers so don't know how good they really work...or maybe they significantly cut down on the number of rodents and there were just a few 'tougher' ones doing all the damage???
    after my kubota tractor got wires eat up, started using dryer sheets on tractor and got 2 cats. moth balls in small dishes set around help with the rest.
    lincoln 125sp
    monkey wards 250 ac/dc
    miller 211 w/spool gun
    ahp 200 sx tig
    lotos ltp5000d
    of course duramax diesel
    Soda springs,Id
    Unless you're afraid of them get a couple of bull snakes and turn them loose. Best mousers around.
    Hobart G-213 portable
  10. #9
    Apr 2014
    West Virginia, USA
    Thanks guys for the ideas. The snake? We have black snakes around but I keep my equipment in a lean-to off the shop and they don't seem to make their way in there. The mice do though. I sort-of like the black snakes but they get to about 5 or 6' and they do startle me once in a while. They used to get into the rafters of one of my sheds and that gets your attention to walk in and have one of those hanging down.
  11. #10
    Aug 2012
    AR
    Double barrel attack.....poison baits and traps. If one don't get 'em the other one will. Some people use those electronic zappers, but the bait and traps are cheaper and work well. If you have animals around that might eat the poisoned mice/rats, just use the traps. Peanut butter in the traps works wonders. I was catching one and two a night for a while, til I had no more mouse problem.
  12. #11
    Watch out for birds making nests, too. I had f$cking starlings make nests on top of the oil-cooling radiator on my air-cooled Deutz diesel in my welder. Thankfully, I discovered the nest before I overheated the engine.
Page generated in 1,600,808,277.01610 seconds with 14 queries
