Results 1 to 25 of 27
Thread: Carriage Bolt Clamp
    Carriage Bolt Clamp
    Sammy's new thang
    Need to do some holes. Fairly accurate, but not SpaceX accurate.
    I've tried to explain how to set up a drill press vise with no drama involved.
    Put the vise on the table, chuck up a center, and get a ruler.................
    Set yer center using the fixed jaw as the baseline..............
    And plop your piece in, and punch a hole.....................gaur-on-teeeeeed to be centered.
    A truly sharp bit, if you gently start it, won't walk. At least for the purpose of a non Uber Critical workpiece.
Size:  241.9 KB Forget all that Drill Doctor BS, get ya one of these. And a General Hardware drill bit sharpening guide/gage.
  2. Likes whtbaron liked this post
  3. #2
    Re: Carriage Bolt Clamp
    Next, we gonna make some buttons............
Size:  190.8 KB These are the rough blanks turned from some scrap (hence the center in one of 'em).
    Next, it's time to dimension the booooogers..........
Size:  211.0 KB Faced them first, then continued cutting the face until the thickness was correct.
Size:  235.5 KB You can get close using the longitudinal feed wheel mic, but for the final few thousands.........use a pancake indicator. Makes ya feel like ya akshully know WTF yer doin'
    Deburr, bevel, and sit back and admire it whilst sippin' the first beer of the evening (This is my weekly Beer Nite)
    So..................where we goin' with this fancified crap???????????????????????
    The buttons have to "float".
    They fits in the leeeeetle hole, and need to be able to scooch around a bit to center themselves.
Size:  209.1 KB I'd tell ya the required diametrical cleeeeeeernce, but then I'd have to kill ya
    Start weldin' the whole mess up tomorrow................Name:  stimpy2.gif
Size:  9.2 KB Well...........after a bit more machinin'...........
    May 2013
    South of Dallas
    I had an old millwright instructor teach me how to sharpen a bit, I use his technique all the time.
  6. Likes whtbaron liked this post
  7. #5
    Quote Originally Posted by Millwrightdude View Post
    The last bench grinder I bought actually has the angle marked into one of the base guards... very handy. I'm curious though, you should post a video of the method you're using....
    May 2013
    South of Dallas
    Its hard to explain, Not sure I could do it in a short video. One thing to always remember, the cutting edge needs to be the tallest part of the bit . I seen guys sharpen a bit and do a good job but the relief part is higher than the cutting edge. Once they lowered the relief so its lower than the cutting edge it cut good. Another thing is tip angle, pay attention to the tip angle, to much angle won't cut worth a crap
  9. #7
    It was all a mystery to me, until I watched this video on Youtube years ago. An older guy who just did it, and explained it simply. I'll try to find the video. MillwrightDude probably uses the same method I'd venture.
    Do 3 passes on each side. Fist 2 passes, you cut your relief angle. The final pass, you get into the the cutting edge, and dress it. 3 each side, and they usually balance out. I use the drill gage to verify what I'm doing. Do not do your cutting edge until the final pass. Do your 3 on the one side, then move to the other side, and do the same 3. You actually remove so little material, and create so little heat, that you don't have to dip the bit till you're ready to use it.
    I don't use the tool rest, I do it all freehand. I use the top of the old cutting edge as a guide. I hold it parallel to the wheel, and work from there. By balancing the cuts (3 each side), you don't take too much off, to the point you've ruined the profile.......you're always in the ballpark.
  10. Likes whtbaron liked this post
  11. #8
    Yeah!!........you're talkin' the relief angle......most guys don't know how to cut the relief angle
  12. #9
    May 2013
    South of Dallas
    I have a bench grinder dedicated to just sharping bits, one rock is for broken bits and the other is very fine for sharpening them.
  13. #10
    May 2013
    South of Dallas
    You can take a bit and almost have a flat tip but with the tip cut right, with the right speed and it cuts so fast with out hardly any pressure. One thing I do is I use a heavy oil for cooling the bit when sharpening, Something the guy taught me.
  14. #11
    I tried to illustrate angles in a boring bar I ground a while back. Not all that fancy nomenclature........just an idea of clearance, and rake.
    Name:  broken wheel121.jpg
Size:  98.9 KB Most metal cutting tools are "point" tools. You put a lot of force in a small area to remove material.
    The vertical angle, back from the tip, towards the center of the cutter, is a relief angle. It gives clearance as the tip bites into the metal. Without this angle, the thing would scrape on the metal, and not cut it.
    The horizontal angle, on the bottom of the cutter, is yet another clearance angle. It keeps the bottom of the cutter from trying to scrape along its entire diameter when plunging into the material. Only the sharp point is cutting.
    Name:  broken wheel123.jpg
Size:  68.2 KB The leading edge of the cut is on the left side of the picture. It's the point. The rounded edge of the tool blank is the relief angle. It provides clearance, and allows the point to be forced into the work, and cut.
    A milling cutter actually has more complicated angles than a drill bit.........drill bits only involve one clearance angle/relief angle. Think of a drill bit as a chisel.
  15. #12
    The coolest thing, and I'm bad about it I guess, is a high rake that literally pulls the tool down into the metal. Almost no down force on the drill. I wouldn't recommend it to someone who isn't willing to resharpen pretty often to dress the edge. It's hard on edges. All about the angle.
  16. #13
    I get pretty excited about this stuff...........it took me a long time to get down to it, and learn it.
  17. #14
    May 2013
    South of Dallas
    It takes practice.
  18. #15
    Jan 2011
    W. Wisc
    I thought this one did the best overall job explaining it, even though it is a bit out of focus at times.
    -Dave
  19. Likes geezer liked this post
  20. #16
    I really don't like that guy, I've watched his stuff.
  21. #17
    Jan 2011
    W. Wisc
    Eh, that's the only video of him I watched, and I thought it covered all the bases well. I just wish there was better camera focus and view.
    -Dave
  22. #18
    Aw Hell, it's a personality thing with his videos. Just my take. It's a matter of the minutia I guess.........mostly useless garble. Just my take. You should see the BS he gets into with a simple lathe bit.
  23. #19
    It's just me...........I'm a grumpy old bastard. Don't take it to heart
  24. #20
    Jan 2020
    This is a bit of a different way of doing it, a very simple way. It's been my go to technique now for a while, works great.
    If you have a little more time on your hands, this guy has some awesome how to videos. One of the most, if not THE most popular diy/homeshop garage tinkering channel.
    As the name suggests, its a long way around. But the guys style and sense of humor make it easy to watch and learn. I havent watched it in a while but I believe he goes and makes a drill bit completely from scratch using a blank piece of rod. Very thorough explanation.
    Sent from my SM-G970W using Tapatalk
  25. Likes whtbaron liked this post
  26. #21
    Mar 2007
    MidWest
    Good instructional vid
    Geezer
    Power Mig 255C
    185 TIG
    Blue 175 MIG
    Ranger 8 Kohler 20HP
    Victor/Harris O/A
    K 487 Spool Gun
  27. #22
    Jan 2011
    W. Wisc
    No worries, Sammmmmmm.
    And yeah - This Old Tony does do fantastic videos. Pro quality, great detail, and they are fun/funny/easy to watch. I just don't always have that kind of time...
    -Dave
  28. #23
    LOL @ "Chowdered right to ****" .... now he's talking my language!
    Got sidetracked yesterday.
    Anyways.........did some slotting today
    This particular slot had to be centered. Take some dye, scribe your mark with a caliper, then line it up with the wiggler. About as good as any method for something that's not particularly overly mogombo critical...........in a sorta get 'er done way. (Probably within about +-.002 )
Size:  212.9 KB The slot isn't for looks. The purpose is to move the center of torque further towards the center of the upright piece of tubing. This way, it's integral with all walls on the upright, and less flexible.
  30. #25
    I'm not too familiar with the settings on the HH190, so I figured I'd just crank it up enough so's it would give me some hopefully good fusion.
    Turns out...........the little booger has a bit more dig than I thought it did. I haven't used it in a while, so I've sorta forgotten where the voltage should be for something like this.
Size:  158.1 KB Name:  mutley.gif
Size:  9.3 KB The idea was to have enough heat for the nut, and focus it on the nut, while letting the puddle flow down into the 11ga tubing. I DEFINITELY GOT SOME FUSION I was doin' good not to burn through the nut
    Today was a weird day............had to cut THREE of these to get the right size.......I did the calculations wrong on the first one, straightened out my numbers, AND CUT THE SECOND ONE THE SAME LENGTHName:  itsok.gif
Size:  1.3 KB......the third try was the charmName:  erniefp.png
Page generated in 1,603,591,186.66348 seconds with 13 queries
