Results 1 to 17 of 17
Thread: Replacement Mig gun
    Sep 2020
    Replacement Mig gun
    Cut my mig gun cable today while grinding... too many things going at once and killed the cable.
    What is a good replacement for me. Just doing small jobs in my shop.
    Hobart 210 MVP is my machine.
    Thanks.
    Dec 2016
    Re: Replacement Mig gun
    bernard are nice. i have a tweco #2 gun with 12 foot leads in really good shape .will need a nozzle and tips .uses standard back end.fits vulcan, tweco,esab,victor and a slew of other machines
  3. Likes Louie1961 liked this post
    Jun 2017
    AJO, ARIZONA
    Quote Originally Posted by JGreen31 View Post
    Thanks.
    That sucks man, I've never had that pleasure but I have cut a welding lead or two, Ebay usually has a good selection and pretty good prices, you can also check some of the online welding stores and AMAZON.
    NRA LIFE MEMBER
    MIDSTATES 300 AMP AC MACHINE
    GOD BLESS AMERICA!
    RONALD REAGAN
  5. Likes ronsii liked this post
  6. #4
    You can make the cable shorter till new comes in.
    Like CAVEMANN said eBay or Amazon.
    There other sources but they ship from China and takes 6 to 10 weeks.
    If you are doing welding for living I using Tweco like filetobeef said, I used Tweco for over 30 years and never had problem.
    Today I am retired so I use the best price
    Thanks.
  7. #5
    CT
    I would visit HTP America. They make awesome replacement MIG guns that are very affordable. I especially like the flex neck MIG guns. https://usaweld.com/collections/avai...rt-mig-welders
    Syncrowave 250
    Purox Metalmaster
  8. Likes ronsii, shovelon liked this post
  9. #6
    Bernard would be an upgrade and are owned by ITW which also owns Hobart. That would be the obvious choice.
  10. #7
    You state there would be lawsuits for using non heated 7018 but would use a lesser quality import Mig gun. You have to do the manufacturer says. Don't do it man, think of all the lawsuits.
  11. #8
    Los Angeles
    Thanks.
    why not a Hobart replacement?
    MM211 (Sold)
    Miller 125c Plasma 120v
  12. #9
    But cover I live in California.
    When trying to sue first thing first x-ray the weld and check see did everything right.
    Most of tools was made in America.
    Just try buying low cost anything in USA or even high cost.
    FYI I was exporting for over 30 years.
  13. #10
    An x-ray will not tell if the rod was in an oven. Many things can cause a weld failure.
  14. #11
    Nov 2004
    Southern Montana
    Thanks.
    Is there some reason you can't just patch the cable?
  15. #12
    Jul 2016
    Midwest
    splice it.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
  16. #13
    splice it.
    I haven't tried to splice a mig cable... I guess anything is possible ??? you could find a rigid sleeve that fits around the liner guide and make sure to chamfer the ends really good on the liner.... might work...
  17. #14
    CT
    They are super nice. I had a 300 amp Q gun for my MM 252, and I loved it, but they are also spendy. For a Hobart 210 MVP, the $89 HTP gun is more than adequate and is an upgrade over the stock gun. Just my opinion FWIW
    Syncrowave 250
    Purox Metalmaster
  18. Likes Broccoli1, ronsii liked this post
  19. #15
    Just for a home shop a basic gun would be fine. Miller has new guns now but the M-25 that came on the 252's was not a very durable gun. For a home shop where someone was really careful it was OK but in a welding shop didn't hold up. I worked in a shop with 6 252's and they kept replacing the guns with more M-25's instead of getting the much better Bernards. They would have saved money in the long run. There was always at least 2 guns hanging up because they were damaged. I had to steal a gun off another machine so I could do my work. Too bad if someone else needed the other machine.
  20. #16
    SoCal-LA
    Agree! They are specialists in mig gun replacements and parts.
  22. #17
    Did get your gun/cable fix and back to welding
    Thanks.
Page generated in 1,603,151,307.73250 seconds with 12 queries
