Results 1 to 13 of 13
Thread: Tractor Fender Repair
    Mar 2014
    Troy MI
    My friend and customer Rickís fender on his tractor cracked on both sides in the rear. On the left side the sharp cracked edges protruded from the fender, so they were a cut hazard. The first picture shows the entire fender.
    1. Fender
    Name:  1. Fender.jpg
    I like to weld bright shiny metal so I cleaned up around the crack on the top and bottom using 1Ē stainless steel brushes in my Foredom shaft grinder.
    2. Removing paint with wire wheel
    Name:  2. Removing paint with wire wheel.jpg
    I used up about 4 wire wheels, because the bristles bend over and eventually break off the wheel as shown below. The edges of the cut didnít line up and surface was compound so the smaller wheel was able reach all areas.
    3. Stainless steel wire wheels Ė worn and new
    Name:  3. Stainless steel wire wheels - worn and new.jpg
    I bought several bags containing 25 wire wheels from eBay for $6 per bag.
    4. Bag of brushes
    Name:  4. Bag of wire wheels.jpg
    Because of the compound surface I taped some Aluminum foil to the back side to trap the shielding gas.
    5. Aluminum foil taped to back side
    Name:  5. Aluminum foil taped to back side.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    7" x 9" Swivel Head Horizontal Band Saw
    20 Ton Arbor Press
    Bridgeport
  3. #2
    Mar 2014
    Troy MI
    Re: Tractor Fender Repair
    The next step was to us a picking hammer and a dolly to straighten out the cracked metal. Then I used a small c-clamp to force the edges of the crack into alignment. The last step was to spot MIG weld the edges together. I used my LE 31 MP with .025Ē wire to minimize burn through on the .048Ē thick fender.
    6. Cracked fender tack welded
    Name:  6. Cracked fender tack welded.jpg
    Next, I completely welded out the crack. Rick asked me to leave the weld reinforcement in the hopes that it would last longer before cracking.
    7. Left top welded out
    Name:  7. Left top welded out.jpg
    8. Bottom left cleaned up
    Name:  8. Bottom left cleaned up.jpg
    9. Bottom view all done
    Name:  9. Bottom view all done.jpg
    Last but not least I primed the area that I welded to prevent rust.
    10. Top primed
    Name:  10. Top primed.jpg
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  5. #3
    Nicely done!
  7. #4
    nice job! is that from a cub cadet?
    lincoln 125sp
    monkey wards 250 ac/dc
    miller 211 w/spool gun
    ahp 200 sx tig
    lotos ltp5000d
    of course duramax diesel
  8. #5
    Mar 2014
    Troy MI
    Quote Originally Posted by duramax-rob View Post
    It is a 1970 Sears Suburban.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  9. #6
    Oct 2012
    Michigan
    Those look like mig welds. and a steel fender so why the backer? Just curious?
    Tim
    metalcraft by moose
    Southeast Michigan
    https://www.facebook.com/Metalcraftbymoose
    Stupid Hurts!!
  10. #7
    Quote Originally Posted by moose View Post
    I believe the backer was to cut down on backside oxidation from lack of shielding gas...
  11. #8
    Mar 2014
    Troy MI
    Yep
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  13. #9
    South Lyon, MI
    Did you drill holes after the cracks? That really helps stop propagation of the cracks.
  14. #10
    Mar 2014
    Troy MI
    Quote Originally Posted by a2lute View Post
    Not this time, I just welded past the end of each crack.
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  16. #11
    The welds look good for FAST welds on thin stuff. Thin stuff usually requires a fast travel speed. Your stuff looks good.
    I can't do this kind of thing anymore. My left eye focuses good at a short distance, and my right eye focuses at about infinity (long distance). Can't get to an eye doctor with this pandemic thing going on, so I've just given up on wire welding that can look good. Simply can't do it anymore, till I get some good glasses.
  17. #12
    The almost blind deal in the left eye makes it a total PITA to even walk. Can't focus on the ground.
  18. #13
    Mar 2014
    Troy MI
    Sorry to hear about your eyes.
    I had excellent vision and didnít require glasses at all, until my 40ís.
    Now As I approach 70 in addition to glasses, I require a really good quality welding hood to see the joint, while MIG welding with thin wire at low current. Itís a 8itch getting old!
    -Don
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
Page generated in 1,603,216,065.20950 seconds with 15 queries
