End table with oak top and stainless legs
Scooped up the wood off the street last week and turned it into this. 4” thick pin oak slab
Re: End table with oak top and stainless legs
Post Thanks / Like - 5 Likes, 0 Dislikes
thats great looking, you should bring that to a custom furniture place or some fancy furniture place and see what they would pay for it...
Can’t. It’s a gift for my girlfriend. Thank you. I’m going to make a plum table and offer that to someone
Weld pic. Same weld. Fast on flash off
Is sliding on the aluminum track difficult, do you lube it?
I used some grease, and it was easy to slide, I’ll put some delrin or the product that’s even slicker and has less resistance then delrin
Looks good Moto. Personally I'd have rounded the corners on the leg brackets. .02¢
how do you plan on keeping the bark from coming off. Every time I so something with slabs, eventually the bark removes itself ?
john
Yes it will eventually come off by itself but this one is kinda glued on right now so it will take a while or need to be bumped off. If You wanna keep it on you need to nail it on or glue it on. I won’t mind when it comes off
Originally Posted by
N2 Welding
It’s chamfered. Won’t matter much anyway. Not sharp enough to hurt someone if they tried
I dig it moto
Saw that router trick on the internet once, looks like a great way to do it.
Cute kiddos
Syncro 350
moto this is a pretty interesting video of a 1 man shop making tables from slabs....maybe has a few ideas for you..oh yeah the table he is making sells for 10 thousand $$$
Hobbytime
That’s a great video. Two take-always, the importance of starting with dry lumber and the slotted holes in the mounting brackets.
Moto, your green oak slab will shrink around 12% in width as it dries. That’s around 1/8” per inch of width. If you don’t slot your mounting holes in the direction of the wood shrinkage, the slab will split severely as it dries.
Miller Trailblazer Pro 350D
Miller Suitcase MIG
Miller Spectrum 2050
Lincoln 210MP
Great job
Keep up the great work.
motolife313
motolife313
Or Teflon shim stock.
Looks good moto.
Enco or MSC carries teflon
You can build one out low cost soft pine for hammering training.
My father did for my older bothers so per nail for me.
I learn only hit the center nail.
FYI The one for hammering is outside in can get loud.
motolife313
Not to be mean, but it sure looks tippy. I guess it'd be ok if it's between a couch, and a wall.
scsmith42
Wow thank you. I will slot them.
I’m going to slot the inside of the frame a inch on each side. 12% shrinkage would be about 2” total shrinkage.
