Results 1 to 25 of 42
Thread: Wear Bar Added to Snow Blower Skid
    Mar 2014
    Troy MI
    My friend Ray lives in the Upper Peninsula of Michigan where they get a lot of snow. He wore out the skids on his snow blower attachment to his Kubota tractor in one season. He sent me new skids and some ¼” x 3” stock. I welded the bars on the skids to extend their life. In the first picture you can see that the heel of the skid is worn almost all the way through. You will also notice that the wear wasn’t even indicating that the shoe wasn’t parallel to the ground.
    1. Worn Skid
    Name:  1. Worn Skid.jpg
    The process that I used was:
    -I cut the ¼’ x 3” to about 10-1/2” long.
    -I scribed the corner radius on the plate and cut it out on my band saw.
    -I cleaned up the radius on my belt sander.
    -I TIG welded the wear plate to the skid in four places. I used TIG because it was all set up.
    -I clamped the skid in the vise and heated the wear bar in the area shown below with an oxyacetylene torch with a rosebud tip.
    2. Heat bending wear bar
    Name:  2. Heat bending wear bar.jpg
    Next, I beat on the wear bar with a hammer to fit it to the skid. I decided to use the heat and beat method instead of my arbor press, because I was concerned with the bend exactly matching the existing skid. Then I MIG welded the wear bar to the skid as shown below.
    3. Wear Bar Welded
    Name:  3. Wear Bar Welded.jpg
    Here are both skids welded.
    4. Two Skis Welded
    Name:  4. Two Skis Welded.jpg
    Here they are primed and painted
    5. Skids primed and painted
    Name:  5. Skids primed and painted.jpg
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250
    Clausing/Coldchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    7" x 9" Swivel Mast Saw
    20 Ton Arbor Press
    Bridgeport
    Lincoln LE 31 MP & Lincoln 210 MP
    Everlast PowerTIG 400 EXT
    Mar 2014
    Troy MI
    Re: Wear Bar Added to Snow Blower Skid
    Here they are installed on the snowblower.
    6. Skids installed on snowblower
    Name:  6. Skids installed on snowblower.jpg
    On my own 1983 Simplicity tractor I am still using the skid that came with it. I just weld additional wear bars on the bottom. After about four wear bars I cut them off and start over.
    Below is a picture of my wear bar on my tractor.
    7. Simplicity skid
    Name:  7. Simplicity skid.jpg
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  3. Likes VaughnT, whtbaron liked this post
    Really good application for some hardfacing on the bottom of the skids. Mild steel wears unbelievably fast on asphalt or concrete.
  5. Likes VaughnT, mbarasing liked this post
  6. #4
    Soda springs,Id
    ^^^^^x 2^^^^
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  7. #5
    Mar 2014
    Troy MI
    ^^^^^x 2^^^^
    Can either of you recommend a good stick hardface rod for this application?
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  8. #6
    Nov 2006
    Stoody 35 is a good all around rod for this. They do make wire for hardfacing as well.
  9. #7
    Soda springs,Id
    Yeah, Stoody rod lays down a nice even bead with good thickness. Just be sure to change polarity. Oh, and get out your wallet, if you know someone who works on a quarry or rock processing plant a half rack of whatever they drink will probably get you a few sticks and they will go a long way for what you're doing. It's what I use on my wheeler plow shoes.
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  10. #8
    Want something for severe abrasion but any general purpose hardfacing will work. Should be able to find in a small 1lb. pack for $25-$30. Lots of specialty rod suppliers have it in the small packages and sometimes the big box stores. It will last 4 times or more longer than mild steel. Some is run reverse polarity but hardfacing you aren't looking for maximum penetration. For those skids run beads parallel to the skids about 3/8-1/2 inch apart and you can put 2 layers for even more wear resistance. Clean the first pass with a wire brush and don't worry too much if you get a little porosity. As long as you get fusion it will work. 1/8" or 5/32" rods would be fine.
  11. #9
    Mar 2005
    Under a Rock
    Nice Job Don...
    I did the same for my Dads snowblower a few years ago....
    personally, I wouldnt hard face it... 1/4" mild steel worked fine.... actually made him 2 sets... so he can swap out if necessary..... easy enough to make...
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  12. #10
    Mar 2014
    Troy MI
    Ryan Jones from the Miller forum sent me some hardfacing rods to try out. My friend and customer was back in town for Thanksgiving, so I asked him to bring back the skids, so I could try out the hardfacing rods.
    The original skid was worn out in one season. We will see how long the hardface skids last.
    The new skid had more surface area than the original as shown below.
    Here is a view of the bottom of the hardfaced new skid.
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  14. #11
    Not to be critical but in that application the beads should be ran the other direction.
  15. Likes ishuum liked this post
  16. #12
    Feb 2009
    Central CA
    I don't know the first thing about snow blowers, so here comes a stupid question...
    Since the skids seem to wear out in short order, isn't there some way to accomplish whatever it is they do with wheels?
    Tim
  17. #13
    The wheels would be outside of the sides of the blower. They would be running on top of the snow on at least one side.
  18. #14
    May 2017
    Pitman PA
    If you can get some good AR 400 plate that would work too, in any case it looks good, that hardface will make it last a long time
  19. Likes theweldor liked this post
  20. #15
    Mar 2014
    Troy MI
    I was worried that if I ran the beads the other way it would cut grooves in the asphalt when you drove the snow blower straight down the driveway. I suppose that the best thing would be weld so many beads that the pad was continuous, so it wouldn't matter which way you ran them. I used up all of the rods that Ryan send to me, so this wasn't an option in this case.
    Quote Originally Posted by timrb View Post
    Tim
    I'm not sure why, but I have never seen wheels on snow plows. Some snow plows have round muchroom shaped skids that are mounted directly behind the blade. Other snowplows that I have worked on have skids on pivots that are also mounted directly behind the blade. I have never seen a wheel on a snow plow.
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  22. #16
    Mar 2014
    Troy MI
    Quote Originally Posted by Popeye an old miner View Post
    If I used AR plate, would the oxyacetylene heating used for bending the plate destroy the hardness of the plate, or would the normal cooling rate preserve the hardness?
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  23. #17
    May 2017
    Pitman PA
    Quote Originally Posted by Don52 View Post
    -Don
    Wont hurt it a bit, just let it cool off like normal, you need to preheat AR plate anyway so there is your preheating
  24. #18
    Mar 2014
    Troy MI
    Thanks,
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  25. #19
    May 2017
    Pitman PA
    -Don
    Wont hurt it a bit, you gotta preheat AR plate anyway so there is your preheat. Let it cool naturally, if you want you can cover it a weld blanket to let it cool slower but it not really necessary
  26. #20
    Soda springs,Id
    Don, if you get AR and cut it with your torch don't start thinking there's something with the torch 'cause AR is prone to blowback when torch cutting. Use an old #2 or #3 you don't care about and turn the oxy pressure up a little.
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  27. #21
    May 2017
    Pitman PA
    Stonebreaker...I dont wanna start an argument but ive never had any trouble cutting AR plate, Ive cut it 3 inch thick and more already, one thing i usually do is preheat the cut line a bit with the weedbuner on the thick stuff, but the normal 1 inch and 2 inch stuff I work with I never had no problem with, generally run about 7 or 8pds acetylene and 55 oxygen and #4 tip. Abit more pressure on both for the 3inch and thicker stuff. Manganese plate will get squirrly though
  28. Likes ronsii liked this post
  29. #22
    Mar 2014
    Troy MI
    So far the skid is working well. the larger area doesn't dig into the dirt portion of driveway and the hardface doesn't gouge the asphalt part of the driveway.
    10. Trying out skids
    Name:  Trying out skids.jpg
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  30. Likes ronsii, VaughnT liked this post
  31. #23
    city of Four Flags
    Tim
    Years ago I refurb'd a snowthrower for one of my Cub Cadet garden tractors and was tired of fixing shoes/skids. I added small pneumatic tires with wings added to the side of the thrower housing, I worked very well. When I was a kid my dad had an old(at the time) Simplicity walk behind snow thrower and it had cast iron wheels that were about 3" in diameter. There was enough weight that they were forced down through the snow and made good contact with the concrete drive.
  32. #24
    Jun 2009
    New York
    Millermatic 211
    Everlast 200DX
    Thermal Arc 181i
    Klutch ST80i lunchbox stick welder
    Lincoln Weld-Pak 100
    Century Stick welder
    Powermax 30 plasma cutter
    Henrob 2000 torch
    Logan 200 lathe (1953)
    Clausing 6339 Lathe (for sale)
  33. #25
    Mar 2014
    Troy MI
    Ray took off the skids for inspection. Now that I know where the skids wear, I can apply a continuous pad of hardface where it will do the most good. The wear hasn’t reached the base metal of the skids yet. Ray said that due to the larger size of the skids, he can’t tip the skids any more to better equalize the wear.
    I bought 10# of hardface rods that are 5 points harder on the Rc scale so they should wear even slower.
    -Don
    Lincoln SP-250
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
  34. Likes whtbaron liked this post
Page generated in 1,713,295,926.50494 seconds with 19 queries
