Results 1 to 9 of 9
Thread: Miller 10E: i need drive rollers-help!
    Jul 2020
    Anybody got sizes other than .045 ?please Let me know
    Re: Miller 10E: i need drive rollers-help!
    You can make your own.
    Just make the V-grove rollers.
    I like using O1 or stress prof.
    They made rollers V-grove , U-grove and knurl rollers.
    It was sales as I found out. I to believe the sales until a employ got rollers mix up. The V-grove worked great.
    Quote Originally Posted by Rilniceguy View Post
    Aug 2016
    Michigan
    I feel your pain, i still have a 10E that sits because the rolls are worn out. You can make your own with tool steel and have them hardened. I've done it before and it worked, but it wasn't on the 10E. I don't know why it would be any different. Have at it!
    Miller Syncrowave 300(s)
    Miller 330 A/BP
    Miller CP-200 Haas / Kamp'd / CP-300 in process
    Miller Radiator 1
    Miller 30A /S-52E feeders
    Hobart GR-303
    The 10E is one best wire feeds
    I would make it or have some make a set locally.
    If I had set of rollers I could make a set today.
    But the largest tool steel I have 1" OD and have buy a full bar not cheap.
    Quote Originally Posted by 86turbodsl View Post
    Aug 2016
    Michigan
    any of the online metal places can sell you shorter lengths of steel. higher $/lb, but still affordable.
    Miller 330 A/BP
    Miller Radiator 1
    Hobart GR-303
    The 10E was always a problem because it used such small diameter drive rolls. It shouldn't be too hard to make some drive rolls though.
    Please upload photos of side wire feeder and rollers removed.
    Are rollers worn out are do need a different size???
    Miller did different drive rollers over the years.
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Jul 2020
    Great info guys. But—the drive gear and roller are all one piece on
    the 10e!
    Sounds like power metal.
    You find a lot of tools had parts made power metal.
    The is good news for you as you pickup a great wire feeder.
    Now how must work do want to do.
    1) make new gear to use off the shelf rollers.
    2) replace the feed roller unit
    Either way you will very good wire feeder.
    the 10e!
Page generated in 1,603,225,293.27988 seconds with 13 queries
