Results 1 to 10 of 10
Thread: question on welding tanks
    Apr 2007
    Poco British Columbia
    Recently moved to a town in BC called Kelowna, the welding tanks got taken up on their sides, so I have left the acetylene upright for over a week, I would think that should allow the gas to settle back into the filler in the tank of acetylene, what do you think?
    Re: question on welding tanks
    Should be fine. They usually tell you 24 hours if laid on there side. It's more so the acetone doesn't leak out and settles back in the cylinder.
    May 2008
    Orange, TX
    A week is way more time than necessary. 30 minutes is considered sufficient.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    I seen wear lay tank down got there location turn tank up and start using the tank.
    If you are worried about tank, best way is contact your gas supplier.
    Quote Originally Posted by partsman View Post
  6. #5
    After a week will be fine. Depending on who you talk to at a gas supplier these days, they might tell you not to use it and exchange it for a new one.
  7. Likes rhunt liked this post
  8. #6
    Apr 2007
    Thanks all.
  9. #7
    Mar 2015
    I doubt Airgas will take a bottle that has laid on it's side,need to rent a bottle.
  10. #8
    Mar 2005
    Under a Rock
    Quote Originally Posted by Jax View Post
    How would they know it had been laid on its side?
    Just go exchange the thing if you’re that worried about it
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  11. #9
    Some suppliers say, if it's laying on its side for a hour, stand upright an hour before using.
  12. #10
    Oct 2019
    Australia
    Our cert theory test, correct answer was 24hrs. Our largest gas supplier, BOC, says 8 hrs. I've seen acetone squirting out of a full cylinder after only 1 hr. Very dangerous.
Page generated in 1,713,248,858.98423 seconds with 18 queries
