Results 1 to 6 of 6
Thread: circuit breakers for 120v welder
    Sep 2020
    Rhode Island
    So how much amp do i need for my circuit breaker to be able to run pretty much any 120v welding machine. my 125 flux core chicago electric runs fine. But my stick welder blows the circuit 2 seconds after striking an arc. It has a weird chart it looks like its a 110v welder from the chart but pulls 40amp. So thats why i am asking how much amps should i buy for a 120v welding machine, my aim is not to get a specific welding machine to work but so that i can buy pretty much any 120v welding machine and use it. My uncle is an electrician so i trying to figure out what i need him to ask to install.
    Trained In
    GMAW 2G (Horizontal)
    FCAW 3G Vertical and 4G Overhead
    SMAW 3G Vertical and 4G Overhead
    GMAW(Pulse) 3G Vertical and 4G Overhead
    GTAW (INTRO)
    Carbon Arc Gouging (INTRO)
    Weld Symbols (INTRO)
    Distrotion Control
    Oxy/Fuel Cutting (INTRO)
    Re: circuit breakers for 120v welder
    That is problem with 120 volt welders
    Most homes have120 volt circuit are 15 or 20 amp.
    But they need a 30 amp breaker.
    If read Forney some they data will show a 30 amp 120volt circuit.
    You may want check company that made the welder
    Others just used one leg of dryer plug note they had a 4 wire dryer plug.
    I fixed the problem selling the 120 volt welder by buying a 240 volt welder.
    Good luck
    Quote Originally Posted by WeldsFargo View Post
    Arizona
    If you are going to the trouble of running a heavy 120 volt circuit why not just go 240? It's the same amount of work and the same number of wires. A 120 volt welder will constantly be a limiting factor to what you can do.
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
  4. Likes BD1 liked this post
    I agree
    I try the 120 two times
    I just gave up on 120 welders
    I was uses to good 240 volt welder and the 120 just did not cut it.
  6. #5
    Definitely consider 220 as mentioned.
    If that's not a option I would run wire for your highest amps to a fused disconnect with outlet. You can use fuses to match machine.
  7. #6
    Jan 2005
    With a decent 120 volt stick machine you can generally have zero issues running about 95 amps output Some 120 volt breakers are more forgiving of snapping ,and will run fine with-in the duty-cycle of the machine.. So change your breaker first.. I have setup a pretty nice 120 volt system with a small plasma cutter, Tiny stick welder, and a flux only mig unit that is flat out awesome. Yes, I can run other stuff on 3 phase 240 and have more output, it just will not travel anywhere as well. Cost To Performance/size is really off the charts if you buy well.
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
  8. Likes DavidR8 liked this post
Page generated in 1,713,275,320.90691 seconds with 18 queries
