Results 26 to 50 of 68
Thread: New score for the shop
    Re: New score for the shop
    High temp Sillycone can be your friend. I don't even bother to weld a crack if it isn't critical.........just put the goo on it.
    Some of us don't do that when the customer is paying $19,000 for an engine overhaul... Plus another 5 grand for other issues with the transmission and other parts of the truck. If it won't weld (which it should) he gets a new cover.
  2. Likes whtbaron, Lis2323, ronsii liked this post
  3. #27
    I can't remember what I paid for the used John Deere one, but it wasn't horrible... I'm thinking less than $300...
  5. #28
    Looks like a deal to me! A word of warning on that timing cover. Some moron who will remain nameless punched a hole in one of my John Deere covers (4440) trying to pry off a dampener pulley (yes, it requires a very stout puller...). I took it to a neighboring Hutterite Colony that does a LOT of work in aluminum and stainless steel. Their conclusion was that it was a white metal alloy, but tried it out anyway. Welding went ok, but every time it started to cool down it cracked and I ended up finding a used one. I don't believe they used any pre-heat, so you might want to try that in a large oven that can heat it evenly and cool it slowly.
    Sounds a lot like an oil pan from a VW diesel Bug a friend brought me, had a little 3/8" hole punched in it so I tried to spiral in to the center... Every time i closed the hole it cracked around the outside of the weld and this was with 300 deg of preheat. I finally welded a 2" diameter patch over the hole and did my best to just barely fuse the weld to the pan without digging any pan metal into the weld. That held for a year 'til he punched it again. Another patch with the same procedure. Dude needs to buy a 1 ton 4X4 for a work rig.
    Yeah, those JD engines do require quite the stout puller for the balancer...
  6. Likes whtbaron, ronsii liked this post
  7. #29
    Cat actually has a pretty good network for used parts if you can find the right sales person. A while back I got a good flywheel housing for $500 that listed new for $3600. WOW.
  8. Likes whtbaron, ronsii liked this post
  9. #30
    I think I actually made one after I broke the cover... used bolts and some scrap iron.... wasn't hard, but that pulley did not give up easily...
  10. Likes 12V71, ronsii liked this post
  11. #31
    Feb 2016
    Oregon
    Yea... I told a nurse once I was going to Crazy Glue a cut shut that they were stitching up for me (there actually is a medical version that they use now, not then). No sense of humor those girls...
    I've used super glue for cuts. Just have to use electrical tape to cover it and not black tape. It leaves sticky black goo when you take it off. Have to use a different color.
  13. #32
    So what's the herd think about the value of this find? I paid $2500... Too much?
    Looks like it's barely used. Serial number will tell what year it is. The Miller cart is probably worth $500 alone.
  14. #33
    It has a shop built cart, it's a good one. The previous owner admitted it probably has less than 3 hours use. It was purchased for an aluminum job that was better done with a spool gun off a Lincoln 255 wire machine due to the plate thickness.
  15. Likes ronsii liked this post
  16. #34
    Would skid mount be better for your shop?
  17. Likes 12V71, ronsii liked this post
  18. #35
    I prefer the wheels when things get clogged up. I have a nice forklift but its pretty wide. It is almost 200' from one end of the shop to the other.
  20. #36
    @Sammmy Post#25:
    The Cyanide based acrylates are your friend where it come to 'stitching' flesh Fast!! Quick and in a hurry.... superglue it that's what the doc-in-a-box does
  21. Likes 12V71 liked this post
  22. #37
    Try welding that cover yet? Just wondering how that went....
  23. Likes 12V71 liked this post
  24. #38
    Sep 2014
    Just make sure you get that machine the proper voltage, or you will be paying as much as twice for your electricity and not even know it. Put a volt meter to it while you are welding aluminum and or check the amps it is drawing. That machine can easily draw 145 amps if there is a voltage drop.
    Sincerely,
    William McCormick
  25. Likes 12V71 liked this post
  26. #39
    Sincerely,
    William McCormick
    I hear ya. Already checked the taps, 230V just like I have in the shop. Worked in a place once that had 2 buildings... One had 208 and the other had 230. Every time you moved a machine it had to be checked.
  27. Likes ronsii liked this post
  28. #40
    Haven't had time yet, gotta get this out by tomorrow afternoon. Then I can play with it. Name:  20201012_141539.jpg
  29. Likes ronsii, whtbaron liked this post
  30. #41
    Quote Originally Posted by rugrat View Post
    That is a very interesting looking engine. What is it?
    1984 Cummins Big Cam NTC400 HP. Burnt a valve so all 3 heads were rebuilt by a nearby machine shop, Got the heads on today, adjusted valves and rebuilt and installed and adjusted Jake brakes today. tomorrow the exhaust and water manifold and turbo and a bunch of wires and oil lines and she'll be up and hauling gravel again.
  31. Likes ronsii, DavidR8, whtbaron, Garfield43 liked this post
  32. #42
    That reminds me... if there's anything you want off this block let me know... I picked up the IP the other day and set it in my sawmill.. it looked ok... so I'm guessing it was unbolted before the hoe moved it
  33. Likes 12V71 liked this post
  34. #43
    Sep 2014
    texas
    Sincerely,
    William McCormick
    Been trying for the last 8-9 years to get my boss to upgrade the wiring/breaker to the syncrowave(digital) 250 in the weld shop. Plate on the machine calls for right about 100 amps on 230. It's been on a 60 amp since before I went to work there. Finally got the electricians in there a few days ago and one put an amp clamp on the disconnect box. I cranked the machine all the way up and went full tilt on the pedal. Electrician went to hollering, telling me to shut it down. Evidently the machine was pulling over 130 amps. Boss finally agreed to have them fix it.
  35. #44
    Waaay outa my league. I'm glad I only have to putter around with little stuff.
  36. Likes ronsii, 12V71 liked this post
  37. #45
    Not really needing any parts right now, and it seems like every time I buy a core engine I use 3 parts and then it sits. I think I still have two 12V71 Detroits that have been sitting for a couple years. The blowers are gone and one is missing the heads. The rest could be scrap if the price ever goes back up.
  38. Likes ronsii liked this post
  39. #46
    Yeah... I know what you mean... gotta store them somewhere... and then when you run outta room and get rid of it you need it the next day
    Saw an ad on craigslist yesterday(monroe area) FREE bunch of stuff on a trailer(included) there was a complete detroit on the back end of the semi(old school) trailer... there was a time when I'd have driven up there right-quick and in a hurry!!!
    .the ad is still up It's still available!!!!
    https://seattle.craigslist.org/sno/h...204791815.html
  40. Likes 12V71, whtbaron liked this post
  41. #47
    Oooh, a 4-53. Oh... Wait... I already have one that does run. You saw it first...
  42. Likes ronsii liked this post
  43. #48
    I was really tempted at first.... but upon looking closer it looks like the cap is off the cover although still could be some good stuff on it... maybe...
  44. #49
    Yeah, I'm betting 4 stuck injectors and a bunch of stuck valves. BTDT with an 8V-71 I got out of Portland once. It sounded like a Turbine when the starter spun it. I got my money back and got to keep the engine. More core parts.
  45. Likes ronsii liked this post
  46. #50
    So... what you're saying is .... the starter is probably good
  47. Likes 12V71, whtbaron liked this post
Page generated in 1,713,253,593.95978 seconds with 19 queries
