Results 1 to 8 of 8
Thread: MiG gas settings
    Oct 2020
    Cleveland
    MiG gas settings
    Hi all, I am a beginner welder and just bought a Vulcan Omnipro 220. I have mig welded a little before but regarding the C25 gas the manual says to check the SCFH value chart for pressure settings and I don’t see them anywhere? Thanks for any input.
    Laredo + Midland/Odessa
    Re: MiG gas settings
    Quote Originally Posted by Mikez View Post
    SCFH is not pressure but rather a flow-rate. Standard Cubic Feet per Hour. Make sure your flowmeter/regulator reads in these units.
    For standard short circuit MIG using a 1/2" diameter nozzle, and 030/035 wire, you need roughly 20 - 35 CFH depending on joint geometry/stickout/breeze/draft conditions.
    Sep 2012
    Utopia,TX / Pasadena, TX
    Most people run 15 CFM indoors.
    Sep 2016
    Detroit, Michigan
    Quote Originally Posted by In Utopia View Post
    How could you know what "most people" are using? It's SCFH not CFM.
    I've seen a lot of folks talk about flow rate for this type of MIG and rarely does anybody mention anything under 20 SCFH.
    http://mivise.com
    Everlast PowerTig 210EXT
  5. Likes Oscar liked this post
    Yep, I sure don't like to go that low (15 CFH), that's for sure. 20 CFH is usually the lowest I go, but I do have a portable AC in my area with another fan helping to circulate cool air so that changes things as opposed to no drafts. If I'm using pulsed-spray then I'm at 25 CFH minimum to acount for a longer stickout.
    Dec 2007
    Los Angeles
    is there a settings chart on the inside of the door?
    Ed Conley
    MM252
    MM211 (Sold)
    Passport Plus & Spool gun
    Klutch 120v Plasma cutter
    SO 2020 bender
    Beer in the fridge
  8. #7
    Oct 2020
    Cleveland
    Thanks for the info...
  9. #8
    Oct 2020
    Cleveland
    I will look again. Thanks
Page generated in 1,713,264,087.06039 seconds with 20 queries
