Results 1 to 25 of 37
Thread: Looking for a plug with a handle
    Nov 2007
    Rockford, Illinois
    I 've been looking for a 220 volt 30 amp power grip/pull handle plug to put on the end of my 8-3 Bus drop welder extension cord, (don't like my hand that close to the blades when I have to unplug from the wall ) can't find a 30 amp 3 wire plug that works with a NEMA 6-50 R receptacle would any one know if someone makes one like I want ?
    or will I have to use a 4 wire replacement plug and set it up as a 3 wire ?
    Thanks for any and all help.
    Joe
    Re: Looking for a plug with a handle
    Quote Originally Posted by steelsmith101 View Post
    Joe
    Why are you looking for a 30 amp cord cap when the receptacle is a 50 amp ? 30 amp and 50 amp plugs I realize are adaptable to either with different prongs that some clam shell ship with you can swap out to make 30 or 50 out of same cord cap but better to just search for a 50 if going in a 50 you may find something but I don't think so.
    Can you just shut off breaker to make it safer for you.
    Or make a handle for it. Buy a clam shell type make a handle and bolt it to the back half of the clamshell with nylon bolts. Very simple to mod one to incorporate the handle you want safely.
  3. Likes Lis2323 liked this post
    Soda springs,Id
    How about just a large zip tie threaded between the blades and around to the front and leave enough slack to get your fingers thru it to pull it out of the receptacle? You shouldn't need your fingers near the blades to plug it in.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Another good idea. Maybe just make some slots/notches in the sides while you are assembling the clam shell and pass it through the inside then it is captured and you can put the Tiewrap coupler end inside the plug so just leaves just a nice loop to pull on.
  6. #5
    Nov 2007
    Rockford, Illinois
    Will I checked with a supply house near me that I use from time to time, they told me they know of no one making what I was looking for. So I will DIMS . I know I should never need something like this But I also have seen what happens when things go wrong.
    Thanks for all of your feed back, take care.
    Joe
  7. #6
    Soda springs,Id
    I googled DIMS and couldn't find any definition that seemed to pertain to your situation, so please explain.
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  8. #7
    Jun 2017
    AJO, ARIZONA
    I've seen plugs with handles used in the RV industry, I didn't pay attention what they were though.
    NRA LIFE MEMBER
    MIDSTATES 300 AMP AC MACHINE
    GOD BLESS AMERICA!
    RONALD REAGAN
  9. Likes farmersammm liked this post
  10. #8
    I guess a guy could get one of these https://www.toolorbit.com/superior-e...63d806438bdcba and adapt it to whatever ya got on the wall or the welder.
  11. #9
    Fredericksburg, VA
    I am guessing he means "Do It MySelf"
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  13. #10
    Hi. I can not get my computer to mark the site. But if you google RV cables and plugs at Amazon .ca
    They have both male and female ends with handles on them. You can get either 30 or 50 amp versions
    I'm sure they are available on e bay as well.
  14. #11
    Rv cables are going to be either straight 120 Hot, Neutral, Ground or 120/240 2 hots, neutral, ground 4 wire type.
    Straight 240 needed for plugging into 6-50R receptacle. You will not find a RV plug in straight 240 volt with 2 hots and ground.
    But yes you can change to that style 120/240 receptacle and not wire the neutral you don't have/need.
  15. Likes ronsii liked this post
  16. #12
    Mar 2015
    Milwaukee, WI
    Use a switchbox to de-energize the receptacle on the cord before manually making the connection.Name:  switchbox.jpg
  17. #13
    Ceres, California
    You can always use the 50 amp twist lock shielded plug.
    Pins are recessed inside a metal shield so there is no chance of your hand contacting a live connection. They are not a nema rated plug and come in single phase and 3 phase styles.
    Also known as a California twist lock plug.
    See them used on welders all the time.
    Another choice is look up the Meltric plug. These all real nice.
    The receptacle is a rated disconnect. Receptacle is dead until plug is inserted and turned. To unplug press the release and plug is ejected.
    Only weak point on these plugs is do not drag on concrete. The ears needed to turn the receptacle on can get ground off. easy to prevent. The Meltric plug parts can be used on cord end or panel mounted. look them up.
  18. #14
    Looking like the RV plug and 50 amp range receptacle is the way to go. Just don't wire the neutral or pull that blade out of the cord cap completely if removeable.
    One of these
    https://www.walmart.com/ip/50-Amp-RV...a8cfe03e245716
    Into one of these
    https://www.walmart.com/ip/Eaton-125...acle/875402075
  19. Likes Lis2323 liked this post
  20. #15
    Jan 2020
    I bought a extension cord 25 ft with a pull handle on the plug that is used for my 240 volt welder. Northern Tool so maybe some one sells a plug with handle.
  21. Likes 12V71 liked this post
  22. #16
    Quote Originally Posted by Bob-O View Post
    I have quite a few of those... but they're all 90degree plugs.... I'm guessing the OP wants a straight plug.
  23. #17
    Straight ones the whole plug/cord cap body is your handle. I was thinking handle on the 90°. They seem to be the ones you have harder time getting a hold of I think.
  24. #18
    Ohhh, I have the worst time getting a grip on them with even the slightest bit of coolant/grease/gunk on my hands or gloves... usually have to loop the cord around my arm to get a good pull on them
  25. #19
    Arizona
    Just this morning my wife gave me the task of cutting up a shipping box for the recycle bin and whadaya know it had this plastic handle on it and I thought of this thread.......a couple pokes with my Swiss Army knife and voila! I never thought about having a handle on the plug but it might be nice to make things easier especially with gloves on. I always unplug my machines due to lightning.
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
  26. Likes Oldendum liked this post
  27. #20
    Arizona
    At 5/64" there won't be any risk of the plug not seating far enough either in case anyone is wondering, especially considering the light amp draw and duty cycle of a small mig machine
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
  28. #21
    With the ground at the top it should only go ground to a single leg when that sheet metal slides down the wall. That is better than phase to phase.
    Just messing with you. Looks good and as long as the box is a decent one and mounted solidly should be great for pulling it right out when your done.
    That thickness will never affect/change the good connection. The blades go in well beyond where the receptacle make contact.
  29. #22
    Mar 2005
    Under a Rock
    thats a nice little caliper... Is that an Amazon special?
    I see a couple similar on there....
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  30. #23
    Arizona
    yep, this one https://www.amazon.com/dp/B07X8JQ8L5...6-ffeb1c8a852f
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
  31. Likes John T liked this post
  32. #24
    Sep 2014
    Joe
    It feels just like 120 volts.
    Sincerely,
    Willam McCormick
  34. #25
    Jul 2011
    Ottawa, ON Canada
    If you can't find one, why not make one?
    4 longer bolts, a piece of plate (aluminum or steel) and a handle of some sort (maybe a steel or aluminum rod welded onto the plate). Drill 4 holes to match holes on the cord end, put the longer bolts in, and you're good to go.
    Heres a photo of the back of a 6-50 cord cap. The 4 bolts go right through to nuts on the other side.
    Handle wouldn't be all that hard to make.
    If the women don't find you handsome, they should at least find you handy!
Page generated in 1,606,680,009.71383 seconds with 13 queries
