Millermatic 211
Hey fellows, I need a board for my millermatic 211 auto set. I’ve had it four years and the board just quit on me. Anyone know where I can find one other than miller?
Miller Dynasty 210
Re: Millermatic 211
I don't believe there are any aftermarket boards out there for the 211's.... you might be able to find a pull on ebay.amz/fb... but it won't be much better than your board was two minutes before it quit
I would pull the board and see if you can find a repair place that will fix it... there are a couple common issues with the 2ng gen 211's that blow a couple components... I'm guessing this is a 2nd gen 211...?
Re: Millermatic 211
Yes it is. It was only a month out of warranty when it blew and miller wouldn’t work with me. The board looks really clean doesn’t look like anything is wrong. But they said the board was out and it would cost 700 to repair it. So I thought I would check here.
Miller Dynasty 210
Re: Millermatic 211
Originally Posted by
bamadogred
If you can... take some good res pics of the board and post them up
I'd be willing to bet it's the same components that blew as a few other threads here on the welding web forum... of course there's always a chance it is something else... but odds favor the common issues
Re: Millermatic 211
Here's a couple pics of the last 211 I had blow... this one took out D45 and D6 diodes... sometimes (most times) it takes out a transistor and maybe a resistor also... but this one didn't....
Re: Millermatic 211
Thanks for the info. My father in-law has it now trying to fix it. I will tell him to take pics and I will post them. I never had a problem with this welder until I hooked my aluminum spool gun and in ten minutes it went down.
Miller Dynasty 210
Re: Millermatic 211
hmmmm. don't recall anything about spoolguns causing issues??? mine have not ran spoolguns.. so yours may be something different???
Oh, the transistor tor the right and down(from the diodes/in the heatsink) is the one that usually blows( I forget the board number) but it's a to220 case or similar IIRC....
Re: Millermatic 211
Curious, where was machine purchased
at ??
We had a issue with a first generation Miller XMT 304. It was 6 months out of warranty and our welding supplier repaired it under warranty. Machine was purchased from them.
Re: Millermatic 211
It was purchased at Airgas. They didn’t want to help much. And we spend a lot of money with them. I bought my other two home welders from another weld supply store. They have been more helpful.
Miller Dynasty 210
Re: Millermatic 211
bamadogred
Air Gas sucked years ago. Now they are even worse. They bought out my local supplier and their cylinder exchanges are off the charts ! I drive 30 miles to a Ma and PA supplier and avoid Air Gas.
Re: Millermatic 211
I agree. I won’t buy another welder from them for sure. Luckily we have young’s welding. It’s a smaller family owned shop, they just can’t get low enough on they’re gas bottles for us to use them solely.
Miller Dynasty 210
Re: Millermatic 211
Glad I bought a first generation 211 when they were phasing them out for the 2nd gens. It was $999 with a $200 mail in rebate. Purrs like a kitten.
Re: Millermatic 211
Showdog75
A fat heavy kitten!!!
Re: Millermatic 211
is a first generation 211 the one with the suite case handle in the top center of the case?
lincoln 125sp
dayton 250 ac/dc
miller 211 w/spool gun
ahp 200 sx tig
lotos ltp5000d
kubota b3200 FEL BH
of course duramax diesel
Re: Millermatic 211
duramax-rob
Yes.
Hypertherm PM 45
1961 Lincoln Idealarc 250
HTP 221
Re: Millermatic 211
This is a picture of the board. And I hear ya show dog 75. I wish I had the first gen. I can’t believe this one sucked.
Miller Dynasty 210
Re: Millermatic 211
I smoked one of those 211's, but it was my fault for not really paying attention to the duty cycle.
Re: Millermatic 211
shame on miller for crapping on you so close out of warranty.
Re: Millermatic 211
Do you know the values of these components? I refer to D6 and D45.
Re: Millermatic 211
Its great to know there is a fix. We had a balancer with a problem, logic i guess but no fix and another plasma i might pull off the shelf to re look at one of these days.
Re: Millermatic 211
I have worked with Miller Electric for over 40 years and never had a problem stretching a warranty over several months. I even had the honor a recall on a transformer in a machine that was 10 years old.
Your problem, as was stated earlier , was your supplier. I always went to bat for my customers and I knew who at Miller who I needed to contact to get things done.
You must remember when buying equipment, its not the company that you are buying from, it's the man representing the company.
His or hers honesty and integerity is what you are counting on with your purchase. I guess that is why my customers buy from me. They know that they get a little part of me with the sale.
Re: Millermatic 211
I know this is an old thread but I was hoping someone my know the value of the resistors that also blow (c63 and c64)
Thanks
