Results 1 to 2 of 2
Thread: I MIG 200E work clamp cable
    Oct 2005
    Guelph, Ontario Canada
    I have the Power I-Mig 200E. The work (ground) cable is kind of short and I would like to get a longer one. Manual says its a DINSE 25 connector. My local Everlast dealer says they do not sell any longer cables. Where can I purchase a longer work cable, and exactly which connector do I need as I've seen that DINSE 25 connectors can be 3/8" or 1/2". I've measured the connector and it's would be closer to 3/8" but not exactly.
    Nov 2008
    Re: I MIG 200E work clamp cable
    Any welding supply store sells cable. You don't need a new connector.
    I guess you may not realize that the DINSE connector comes apart and the cable is held in by a set screw? This is S.O.P. if you wan to lengthen your cables. Pull your boot off the DINSE and undo the cable. Put a lug on the other end for the work clamp (avaialble at any local welding supply store as well) and reattach it.
    Dinse 25 cables are only 3/8" (nominal, but not exact), not 1/2.
    By the way, the rule of thumb is no more than 2/3 the length of your MIG gun for work. This is fairly standard recommendation throughout the industry.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
Page generated in 1,713,295,605.14229 seconds with 17 queries
