Results 1 to 25 of 26
Thread: How to make a dead end cap on tubing?
    Anybody got a template or layout technique for forming a dead end cap on pipe/tubing?
    I am capping a piece of 6 inch tubing. Non structural use.
    Thanks.
    Aug 2018
    'ta town, KS
    Re: How to make a dead end cap on tubing?
    Subtract 1 wall thickness from the size... i.e. 1/2 wall make it 5 1/2 x 5 1/2. Center, tack and weld out.
    Mac
    Feb 2019
    Snyder TX
    They call that a bull plug. Maybe do a search for that. The pipefitters handbook by Thomas Franklin gives step by step to build one.
    On this link use procedure for a welded tee i.e. saddle the end & re-use the cut out from the branch for the end.
    http://navybmr.com/study%20material/...14251A_ch2.pdf
  6. #5
    Feb 2015
    Texas
    I did a write-up about this with emphasis on the layout. https://weldingweb.com/vbb/showthrea...ipeliner+grill
    Miller 350 Dynasty
    Miller Trailblazer
    Miller 625 Plasma
    Lincoln Power MIG
    Victor oxy/acetylene
    Hyperthem 85
  8. #6
    There is also the "orange peel" cap...
  10. #7
    A forged pipe cap may fit too.
  11. #8
    If you can find one that fits True 6" OD tube. In irrigation work I deal with both tube size pipe and regular Iron pipe sizes. The IPS caps will slip over 6" tube and allow a nice fillet weld.
  13. #9
    My former made a deal for some drill stem for his fence and slipped pipe caps over the drill stem for the post tops. Rolled them to put the fillets weld on and the caps were slightly flattened by the post pounder but looked pretty neat.
  14. Likes 12V71 liked this post
  15. #10
    Thanks folk. I was actually looking to make that particular Bullnose/dead end cap. I will look at Blucllplt's thread.
    The orange peel, appears to be more popular and comes up under Bullnose search.
  16. Likes ronsii liked this post
  17. #11
    Hmmm
    So, I go to a file cabinet in my office with some pipe layout tools I never use. Literally new in box. One tool is a curve-o-mark contour. In the manual is instructions/layout for a Bonnet head pressure cylinder. Looks like a Bullnose/dead end cap to me.
    My kids would say you deserve a neck for that... Then slap me on the back of the neck....
  18. Likes 12V71, ronsii liked this post
  19. #12
    Feb 2015
    Texas
    I’ve used the curv-o-mark to layout pipe for end caps and branch fittings. There is a thread by kuzineddie (sp?) that I think addresses using one for the bullhead type fitting.
    Miller 350 Dynasty
    Miller Trailblazer
    Miller 625 Plasma
    Lincoln Power MIG
    Hyperthem 85
  20. #13
    Yeah, Thanks. I am sure your thread and kuzineddie's thread are the reason I have these pipe layout tools. Even got the drywall tape...
  21. #14
    Took a couple of attempts to get the saddle to fit. I only had a couple pieces on tubing at 7ish inches each. So, the contour tool would not work. I ended up cutting a template for the saddle after the fish mouth was cut. I used drywall tape to for layout the fish mouth on the tubing. And gasket material to wrap over the top of the fish mouth to trace/cut a template for the saddle.
    I look forward to another attempt when I have more tubing. Probably doesn't take too long for those who know what to do.
    Thanks for all the suggestions.
    Looks like an owl?
  23. #15
    Feb 2015
    Texas
    Looks like it came out very well!
    Miller 350 Dynasty
    Miller Trailblazer
    Miller 625 Plasma
    Lincoln Power MIG
    Hyperthem 85
  24. #16
    Western, NY
    Looks good !!
  25. #17
    Nothing wrong with that.
  26. #18
    Dec 2009
    Las Vegas, Nevada, USA
    That does look great.
    Question: Why is that bull head curved cap any better / worse than just a round disk welded in place with tube cut straight at a 90 degree angle?
    The reason I'm asking is this... (is it worth the effort to add an additional tab "Dead End Cap")
  27. #19
    Oct 2019
    Australia
    Quote Originally Posted by zipzit View Post
    For non pressure purpose it's ok. Flat surfaces don't stand up to pressure very well, the slightest billowing can crack the weld and the plate will fly off - not good. Can be done though by using thick plate (like 5/8") set inside the pipe and plug/fillet welded. Had to do this a few times when a pipe needed capping off on a weekend and no butt weld caps available. Even so I would avoid this on pipe over 3" if possible or plan to replace it with a proper butt weld cap asap.
  28. Likes 12V71, tapwelder, ronsii liked this post
  29. #20
    Apr 2010
    12V71
    ^ ^ ^ by Thomas Franklin = the 'Gold Standard' of Pipe fitting -
    I have a masterful E6010 hand - this is child's play . . .
    hth
    Opus
  30. #21
    Dec 2009
    Quote Originally Posted by BluCllrPlt View Post
    Blu... That's a pretty impressive posting. I'd like to ask about one aspect there, and that is the bevel (to accommodate weld bead). I'm seriously thinking of adding this joint to the tubenotcher program, and I'd like to program that bevel.
    • If I were to make that joint with the intent of brazing it, I'd want zero bevel, maximum material contact throughout the joints full thickness.
    • If I were to use stick / MIG / TIG a preformed bevel would make the job go easier.
    What's the right bevel "angle". Your example started out at 45 degrees per side (90 degrees total), but is that optimal? Anybody know? Is 37.5 degrees a magic number?
    My tendency it to create the patterns with inside surface dimensions = zero gap (line to line), and provide an option for outside surface bevel (none or 90 degrees or X degrees?) What makes sense here? Your thoughts?
  31. #22
    I would think the angle would change with wall thickness. Since the wall thickness would need to be accounted for for it to sit flush and the upper edge would need to match the od of of the material.
  32. #23
    Feb 2015
    Texas
    I got the 45 degree angle from the pipe fitter handbook. Not sure how you would have to cut the pipe to avoid any bevel; I’m working on a YouTube video right now that might help to explain my layout procedure in real time as I draw the template. When it’s done I’ll share the link with you.
    Miller 350 Dynasty
    Miller Trailblazer
    Miller 625 Plasma
    Lincoln Power MIG
    Hyperthem 85
  33. #24
    Feb 2015
    Texas
    All the texts/handbooks I have read only indicate a 45 degree angle. In the morning I will submit a photo of the angle that I think you have a question about.
    Miller 350 Dynasty
    Miller Trailblazer
    Miller 625 Plasma
    Lincoln Power MIG
    Hyperthem 85
  34. #25
    My apologizes. I was just considering my limited experience. Look forward to your photos.
    The curve o Mark contour direction said cut perpendicular to the wall. So 0 degrees?
Page generated in 1,606,283,844.77433 seconds with 13 queries
