Results 1 to 11 of 11
Thread: Wicked spatter with flux core wire
    Sep 2020
    VT
    I've been experimenting with my "new" setup (XMT 304 with a a Hobart Hefty), and I just put a spool of .035 flux core wire in it and I'm getting terrible spatter and BBs everywhere. Maybe I have some settings wrong or maybe I'm just forgetting how messy flux core is. Haven't used it in quite a while. Usually using solid wire. Any suggestions?
    Glen
    Red-D-Arc EX300 (Miller XMT304)
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Re: Wicked spatter with flux core wire
    Looks like the voltage may be a bit high. Turn down to 17-18 or so. When I run .045 on the Trailblazer with one of the Miller VS feeders, I usually start at 19-21V on the machine end and dial in at the feeder.
    PS... You are wire negative, right? I forget that once in a while myself.
  3. Likes ronsii, CAVEMANN, MinnesotaDave liked this post
    Need to fill in some more details. What flux-core wire, are you running on CV, correct polarity for the wire, etc. Looks a little cold/lumpy to me. More volts generally flattens the bead a little but may need to experiment a bit with settings. Check polarity first.
  5. Likes CAVEMANN liked this post
  6. #4
    Sep 2020
    VT
    I bet it's wrong polarity...
    Thanks for the tips. On my champion there is a polarity switch but with the XMT I have to swap the leads so I hadn't thought about it. It is gasless Forney wire, I'm fairly certain I had it on CV, and probably around 20-21 volts.
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
  7. #5
    Laredo + Midland/Odessa
    and don't forget a longer stickout compared to solid wire MIG
  8. Likes 455dan liked this post
  9. #6
    Jun 2017
    AJO, ARIZONA
    I seems like I get more spatter with the Forney wire, I prefer NR-211, but can't get it locally.
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    JEFF
  10. #7
    Apr 2008
    NW ON Canada
    Never really been of big fan of using self shielded wire. I much prefer gas shielded flux core wire when it's possible. I even prefer to use stick over self shielded wires.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
  11. #8
    Sep 2020
    VT
    Quote Originally Posted by snoeproe View Post
    Agreed, unfortunately I don't have a tank or regulator for this at the moment...
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
  12. #9
    Apr 2008
    NW ON Canada
    I’ve had a spool of Hobart 21b wire in my suitecase feeder for a while.
    Jason
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
  13. #10
    I agree with Oscar
    I think it is most common problem I see.
    It so bad my shop purchased long Nozzle for all welders.
  14. #11
    Mar 2005
    Under a Rock
    Wicked Pissah !
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
Page generated in 1,713,260,357.43448 seconds with 19 queries
