Re: New to welding question.
I'm not sure. If cast iron, find a way to fasten that doesn't involve welding. If wrought iron, find a way to fasten that doesn't involve welding.
You have an antique there. A first timer welding to it will destroy its monetary & aesthetic value.
How do posts attach to the ground? are they hollow & sit on a steel post?
How do fence sections attach to posts. I presume screws?
I'm betting existing hinges bolt to the post & in turn to the gate. Fabricate new hinges that bolt in place if needed.
There are sure to be breaks somewhere. Were they repaired with weld?
