Results 1 to 7 of 7
Thread: QUESTIONS: DIY Automated blasting material sifter
    Bilbao, Spain
    Gents,
    I got a situation. A few months ago I bought (used) a comercial pressure pot blasting unit. Homegamer sized, holds 30kg of blasting media. I even think I talked about it here.
    Yesterday I had the chance to try it and even though I purchased propper aluminium silicate media in a fine grit, the media didn't come as pure and pristine as I would like, and it presents bigger than usual particles that clog my nozzle.
    Sifting it through the provided (with the machine) screen is the answer. But is slow and tedious.
    I want to make an automated sifter for the new media and also to allow me to reclaim the used abrasive.
    I just saw this particular design in Youtube and seems very veeeeeeeeeeeery simple.
    However, I would like to modify it to allow me to place it above the pressure pot so the sifted media falls right inside (funnel shaped bottom. I would also make it out of metal and hold the screen itself on rubber plugs or springs to isolate the vibrating part from the structure. I think it would be wise to make it somewhat slanted so the big particles slide to a secondary deposit to be disposed properly.
    For the vibration I was thinking of using pneumatic turbine vibrators. They are supposed to be cheaper and more robust. They also don't require electrical power, so I could just use it with the same air I power the blaster (when outdoors). Something like this:
    TURBINE VIBRATOR
    Question is I have no idea if I should choose one from the K line or GT line... I read what I could find and both models seem to be used in automated sifters.
    Anyone here has any clue about which one should work better? Usually bigger is better but I don't think I need to go monster big for this application, as it is not to big of a contraption. K10 maybe??
    Oh! And I was thinking of fitting two vibrators in series, one for the X axis and another one for the Y axis to provide vibration in both directions. Althoug I might get by fitting only one diagonally in the screen frame. Thoughts?
    Mikel
  2. Likes thegary liked this post
  3. #2
    Long Island
    Re: QUESTIONS: DIY Automated blasting material sifter
    I’ve used a HF pneumatic jitterbug sander to shake a screen table before. It’s about all it’s good for.
  4. Likes Mikel_24, ronsii, walker liked this post
  5. #3
    Bilbao, Spain
    The guy in the video I linked used a jigsaw with the saw blade removed, so I guess he didn't need much vibration for it to shake the media. I just want to be DOUBLE SURE... As long as it doesn't rattle the thing apart... its all good!
    Mikel
  6. #4
    Bilbao, Spain
    I just bought two K-10 vibrators and the 1mm stainles steel screen... Now I just have to wait for the items to arrive. Will report back once I start the build.
    Mikel
  7. Likes whtbaron liked this post
  8. #5
    Sep 2005
    Cave Creek AZ
    You could always simply buy higher quality media.
  9. Likes rlitman, Mikel_24 liked this post
  10. #6
    If you want to re-use the product, you'll still need the screener for the 2nd/3rd time around...
    Bilbao, Spain
    True, I fully agree with you. I buy it locally from a blasting media manufacturer and actually it is supposed to be well withing the aceptable size range for my blaster and tip. I am saving the big pieces that I find during the (for now) manual screening process to ask them about it. I guess there is always some bigger pieces to be expected but... how much of it (%)?
    True as well. Even though I still don't have a cabin, I plan to do it outside over a tarp with some kind of sidings and re-use whatever falls in the tarp. So yes, I need to screen it anyways.
    Mikel
Page generated in 1,713,277,734.34360 seconds with 18 queries
